Canon 2800 needs help
  • Gina82
    • Oct 2017
    • 98
    [Jamming] Canon 2800 needs help
    I have a canon 2800 that gives a stationary jam after paper leaves fusing unit but before it reaches the delivery sensor. The paper stops in the middle of the vertical transport to the delivery section. I think it may be to M5 motor but when I go into service mode the motor always operates fine. If I go into the jam history I see a common pattern of a 0114 jam code but if I am not mistaken that would refer to the PS19 delivery sensor that it never reaches. Any ideas?
  • copier tech
    • 8222
    Re: Canon 2800 needs help
    Is this the Canon IR2800 mono machine?
    When the grease dries out in the fuser sleeve you get fixing unit jams usual for a motor to fail.
    • Gina82
      • Oct 2017
      • 98
      Yes it is for the Canon IR2800 mono machine.The copy makes it out of the fuser successfull but when it is headed towards the exit it stops in the door every time.
      • Andyboachie
        • 185
        How often is does the jam occur? Every copying process or occasionally? In the meantime, don't forget to check the work of sensor flags. A weak spring on a sensor flag of previous sensor can be a culprit. Also check on clutch to see if it sticks or functions poorly. I hope you get round it.
        • Brian8506
          • 1667
          I've had to add an extra wrap to the fuser exit sensor spring. Check sensor flag operation
          • Gina82
            • Oct 2017
            • 98
            Do you think the fusing unit actuator is the issue even with the paper making it out of the fusing unit and the jam is a constant jam
            • roho
              • Mar 2009
              • 844
              Yes, very well could be as the flag is late to return to it's position as paper passes. The sensor being slow then gives the machine the impression the page is still over it, when it has moved on. The sensor arm at the fuser exit was a common problem, I cannot remember the jam code for that particular issue as I worked on these well over 15 years ago.
              • Brian8506
                • 1667
                Yes I do think they can still be the sensor flag. What is the jam code?
                • roho
                  • Mar 2009
                  • 844
                  He posted it was 0114
                  • Brian8506
                    • 1667
                    Does the machine have a finisher? Entrance sensor on that can cause that if its bad or knocked out of place
