IR1025 Drum
  • Brian8506
    • 1664
    IR1025 Drum
    Wondering if anyone has had problems with the OEM drum units prematurely throwing the waste toner, change drum message. Drum unit clicks and the housing container is close to empty. Usually I have to put in another drum unit. This happens on probably half the drum units and I probably get 5-8k out of them when they go prematurely. Nothing on the knowledgebase. TIA
  • GIUBOSS
    • 1433
    Re: IR1025 Drum
    you should check in the polarization contacts of the drum that does not make good contact. Try here:
    IR1023 System Error E019
    • copier tech
      • 8144
      Re: IR1025 Drum
      You will always get this issue with non OEM toner or if the printer is in a high temp/humidity environment
      • Brian8506
        • 1664
        Re: IR1025 Drum
        No error codes. Just clicking and a waste toner message. Copies are fine.
        • bobburnsreb
          • Mar 2015
          • 233
          Re: IR1025 Drum
          Are you clearing counters?
          • Brian8506
            • 1664
            Re: IR1025 Drum
            No never explored any counters on this model since it came out other than total count. It's mechanical. Waste toner drive is binding
