Canon IPF 755 Plotter Hardware Error 03130031-2618, I got this error then put a new printhead in and then "Right after power up got a "Need to change printhead" error. One thing I notice here is that there are large gaps of air by the printhead clear tubes. In the book it says to check the power supply unit. I am new to plotters and wanted to get a second opinion. So should I replace the Power Supply QK1-5141-000 ?. Thanks so much for any help !!!
Re: Canon IPF 755 Plotter Hardware Error 03130031-2618
For me, it was the printhead.
This is the advice I got here at Copytechnet:
VH high voltage error. In order of likelihood can be caused by the printhead (60%), main board (30%), head relay PWB/carriage relay PWB or ribbon cables (10%).
First replace print head (2251B003AC). Second check ribbon cables and connections. Third replace main board (QM3-3215-000). Fourth replace carriage assy (QM3-3330-000) or separately carriage relay PWB (QM3-3221-000) and head relay PWB (QM3-3229-000). Fifth replace carriage ribbon cable.
=^..^=If you'd like a serious answer to your request:
