Dirty at line
  • Alan3723
    • Oct 2020
    • 4
    [Misc] Dirty at line
    Help me with this problem..machine model is ir 3235..
    Already replaced drum & blade, new lower roller & film and also already tried change toner tank..
    • 36869
    Re: Dirty at line
    That looks more like a developer problem to me.
    • Brian8506
      • 1658
      Re: Dirty at line
      Looks like a developer problem to me too
      • tsbservice
        Field tech
        • 7917
        Re: Dirty at line
        Blured line and letters near to it. Does this line repeats at same interval. If so measure the distance.
          • 8104
          Re: Dirty at line
          Classic compatible toner issue.
          Rebuilding the drum won't help & I bet you only replaced the fuser film not the film assembly, again not helping as you have to apply the correct amount of grease to the heat element.
          • Alan3723
            • Oct 2020
            • 4
            Re: Dirty at line
            already change with other developer but same problem..
            • Alan3723
              • Oct 2020
              • 4
              Re: Dirty at line
              everytime same problem.. don't know how to solve
              • Alan3723
                • Oct 2020
                • 4
                Re: Dirty at line
                I've another same model machine & use compatible toner too but those machine doesn't have this problem.. Example i have 10 machine only 2 maybe come with this problem
                  Re: Dirty at line
                  Some compatible toner is inconsistent from batch to batch even though it's from the same company. Just saying....
                    • 36869
                    Re: Dirty at line
                    Inconsistency due to lack of proper quality control is always a potential problem with aftermarket supplies.
                    • Drivee
                      • Nov 2020
                      • 322
                      Re: Dirty at line
                      This is 100% low quality toner. This is air in toner and in the time when page go in to heater, line explode, bubble with air explode. That is reason why you see this. I use Data product cartridges and they are fine.
                      You can solve this will lower dencity on black. It will help.
