IR3300-E064
  • davidj7
    • 1107
    IR3300-E064
    Hi,
    My two IR3300 machines are showing E064 error . I traced the problem in both the machines to the Feeder Unit .I put in another feeder unit from a different machine and the problem is solved. My issue is what could be wrong with the feeder unit which causes E064?.There is nothing much in there to go wrong I cleaned the unit ,checked for any cracks,wear and tear, no luck. Any suggestions please
    a machine is only as good as your tech : source:screwtape ; the scary one
  • 11x17
    • Apr 2007
    • 153
    E064 is a high voltage error and is usually solved with a new drum
    • SCREWTAPE
      • Aug 2025
      HVT problem.. Don't understand how the feeder is related with that E- code. I guess anything is possible.
        • 23010
        This is just speculation. but the document feeder has nothing to do with Eo64. This is a composite power supply failure, which can be intermittent. My guess is that you'll be back to work on this issue again. =^..^=
        • davidj7
          • 1107
          yes i know logically speaking and going by the manual E-064 could be either power supply or drum unit I changed all the boards even the MFC just to be sure.Not a single copy comes out till i change the feeder unit
