Not Printing in straight line
  • princepriyu
    Canon IR 3300
    printing ZIG ZAG even when i do a photocopy or print from a PC
    Looking at this I have replaced with a brand new OPC DRUM
    but problem is unsolved
  • Brian8506
    • 1665
    Re: Not Printing in straight line
    Laser unit.
    Sent from my iPad using Tapatalk
    • Brian8506
      • 1665
      Looks like you also have a drum problem. Did you put in a new OEM?
      • princepriyu
        tried with two new OPC drums
        NO CHNAGE
        Prints same
        • Brian8506
          • 1665
          • Brian8506
            • 1665
            Have you checked dv unit for vertical lines problem.
              • 23010
              His images are LEF. That's the laser motor speed varying. All laser as far as I'm concerned. =^..^=
              • allan
                RTFM!!
                • 5462
                There are snake skin patterns on that print. Some arching somewhere?
                Seen this kind of thing but without the funky zig-zaging.
                A voltage leak from the mag roller to the drum somehow.
                In your pic you can see its only from one end.
                Wow its the weirdest thing i have seen in a while.
                Where it arch from the one end it draws a void to the other.
                The zig-zag looks like an added effect.
                Whatever
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  • tsbservice
                    Field tech
                    • 8031
                    Looks like you may have 2 separate problems. Like others said Laser unit and probably developer unit mag roller.
                    • Gab
                      • Aug 2015
                      • 676
                      Is scaner at the optics moves smoothly? Check it.
