Firmware for IR 6255i
  • sittingpretty
    • Sep 2015
    • 34
    Is there a possibility to extract the firmware data from a working IR6255i machine to enable me to use SST to format another hdd for another machine? Ty in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5016
    Re: Firmware for IR 6255i
    No, but you can update printer with cds updater in service mode.
    • sittingpretty
      • Sep 2015
      • 34
      This is in service mode, yes? Connecting the machine via network I can opt to update firmware. With the SST I can obtain a copy with my service pc running the SST. Can I opt to backup my old firmware along the way? What I meant is will the update be initiated in the machine menu or the SST itself?
        • 2619
        You can update the machine from management settings, you don't need sst, firmware or service mode just an active n/w connection.
        • sittingpretty
          • Sep 2015
          • 34
          I have an identical machine with defective HDD, no format firmware installed on SST. Need them both copier working to finish a project. Was just looking for another option to get them working.
          • copier tech
            • 8299
            You could simply swap the HDD, i've never tried but in theory it should work. If it does work clone the HDD to a new HDD & fit this back to the donor machine.
            Or the correct way use the SST to upload the SSW to your new HDD.
            • sittingpretty
              • Sep 2015
              • 34
              Once I have downloaded it in CDS can I access the files in SST and do the update there? TY
              • copier tech
                • 8299
                No, with CDS you can only download & update the machine. You don't need the SST when using the CDS updater.
                But you need to use the SST if your HDD has failed with an E602 error etc.
                • sittingpretty
                  • Sep 2015
                  • 34
                  one of my machine has a mirroring kit, can i use this to make a copy?
