Firmware for IR 6255i
  • sittingpretty
    • Sep 2015
    • 34
    Is there a possibility to extract the firmware data from a working IR6255i machine to enable me to use SST to format another hdd for another machine? Ty in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Firmware for IR 6255i
    No, but you can update printer with cds updater in service mode.
    • sittingpretty
      • Sep 2015
      • 34
      This is in service mode, yes? Connecting the machine via network I can opt to update firmware. With the SST I can obtain a copy with my service pc running the SST. Can I opt to backup my old firmware along the way? What I meant is will the update be initiated in the machine menu or the SST itself?
        You can update the machine from management settings, you don't need sst, firmware or service mode just an active n/w connection.
        • sittingpretty
          • Sep 2015
          • 34
          I have an identical machine with defective HDD, no format firmware installed on SST. Need them both copier working to finish a project. Was just looking for another option to get them working.
            • 8139
            You could simply swap the HDD, i've never tried but in theory it should work. If it does work clone the HDD to a new HDD & fit this back to the donor machine.
            Or the correct way use the SST to upload the SSW to your new HDD.
            • sittingpretty
              • Sep 2015
              • 34
              Once I have downloaded it in CDS can I access the files in SST and do the update there? TY
                • 8139
                No, with CDS you can only download & update the machine. You don't need the SST when using the CDS updater.
                But you need to use the SST if your HDD has failed with an E602 error etc.
                • sittingpretty
                  • Sep 2015
                  • 34
                  one of my machine has a mirroring kit, can i use this to make a copy?
