Vertical White streaks--From Fuser???
  • thadwald
    • Feb 2014
    • 74
    [CQ] Vertical White streaks--From Fuser???
    I have a Canon IRC7055 that has recently started leaving a white streak down the page. PG 5 prints with individual colors indicated that it happens with all colors. I printed a pg 5 with black 255 and interrupted the print. The defect is not visible immediately before the fuser.
    Any thoughts?
    pg 5 K 255
    pg 5 CYMK 128
    pg 5 K 255, partially fused
    • 23006
    Re: Vertical White streaks--From Fuser???
    Yes, looks like fuser to me. =^..^=
    • thadwald
      • Feb 2014
      • 74
        Replace w/ known good used fuser,?
        • thadwald
          • Feb 2014
          • 74
          I am now pretty sure the fuser is the issue.
          It appears that the metal film inside the pressure belt has split in two at the white streak. This probably causes leaky induction heater eddy current shenanigans.
          Unfortunately all my used fixing assemblies have a bad pressure belt ...
          I'll post back once I get the new parts in.
          Thanks.
