Error machine iR C3226
  • no_bct
    • Feb 2023
    • 37
    My machine error e602
    How to enter download mode for update firmware machine, because no button in panel
    Thanks for help
  • copier tech
    • 8132
    You need to prepare a USB stick using the Canon service support tool (SST) with the system software to reload the firmware.
    We can supply this if required.
    www.printerfirmware.co.uk
    โ€‹
    • no_bct
      • Feb 2023
      • 37
      I already have it, but don't know how to enter download mode. For the IRA model, usually press the 2+8 buttons. I don't know about this model. can you help me?
      • no_bct
        • Feb 2023
        • 37
        which button should I press to enter service mode?
        • copier tech
          • 8132
          That model is not sold in The UK.
          Do you have the service manual ?
          โ€‹
          • bobburnsreb
            • Mar 2015
            • 229
            • copier tech
              • 8132
              That will not help as the device is not booting up.
              โ€‹
              • copier tech
                • 8132
                Hold down [Counter Key] and [Stop Key] while powering the device on to enter download mode.
                โ€‹
                • no_bct
                  • Feb 2023
                  • 37
                  Thanks for help, its work
                  • copier tech
                    • 8132
                    No problem. I got that info from the service manual.
                    โ€‹
