Canon C5235I
  • Gadibh
    • Sep 2021
    • 8
    [Dead] Canon C5235I
    Hi guys.
    i have Canon C5235I machine.
    when i started out the machine, all the system up, except the engine.
    there is no sounds except the fans (no engine sound).
    techincal guy told me to repplace the controller. i orederd one and it's still not working.
    thanks for helping!
    Gadi
    Re: Canon C5235I
    Originally posted by Gadibh
    Hi guys.
    thanks for helping!
    Gadi
    Are you a tech? Do you have a service manual?
    • Gadibh
      • Sep 2021
      • 8
      Re: Canon C5235I
      Hi and thanks for your answer.
      i'm technical but not tech.
      i dont have service manual just the regular user guide.
      regards.
        Re: Canon C5235I
        regards.
        You shouldn't be working on it if that's the case.
        • Gadibh
          • Sep 2021
          • 8
          Re: Canon C5235I
          I just want to know what is the issue and what part i need.
          its cost me alot of money and time...
          all the best
            Re: Canon C5235I
            all the best
            Get the manual...
            Are there any error codes?
            • Gadibh
              • Sep 2021
              • 8
              Re: Canon C5235I
              Get the manual...
              i'l looking for it.
              No. there is no error code.
              • copier tech
                • 8169
                Re: Canon C5235I
                i'l looking for it.
                What do you have on the screen? Are there any LEDs on or blinking?
                You will need the service manual it has a step by step troubleshooting chapter.
                • Gadibh
                  • Sep 2021
                  • 8
                  Re: Canon C5235I
                  hi.
                  there is blank on the screen.
                  i found the service manual here the file link: Dropbox - imagerunner_advance_c5255.pdf - Simplify your life
                  i dont know to find the troubleshooting.
                  regards
                    Re: Canon C5235I
                    hi.
                    regards
                    You are above your level higher a trained tech.
                    • Gadibh
                      • Sep 2021
                      • 8
                      Re: Canon C5235I
                      Ha Ha. thank you. why you say that? (-:
                        Re: Canon C5235I
                        1) you ordered a board w/o proper diags
                        2) non copier tech
                        3) no manual
                        4) no idea of what's going on.
                        • Gadibh
                          • Sep 2021
                          • 8
                          Re: Canon C5235I
                          2) non copier tech
                          3) no manual
                          thats why i need you.... (-:
                            Re: Canon C5235I
                            We here at CTN are only as good as the info supplied.
                            PERSONALLY I would never order/replace an expensive board until it was certain that the board is the culprit.
                            Read the manual then read it again ... concentrate on the TROUBLESHOOTING section.
                            • Gadibh
                              • Sep 2021
                              • 8
                              Re: Canon C5235I
                              you allright....
