CANON C3330i Firmware
  • mkarip
    • Feb 2010
    • 33
    [Dead] CANON C3330i Firmware
    I need the firmware for an C3330i.
    Plus instruction which data is necessaray on USB Flash Drive
    Error on bootup: E602-0101
    Thank you very much.
    info@compax.ch
    Re: CANON C3330i Firmware
    info@compax.ch
    PM Copier Tech
    • mkarip
      • Feb 2010
      • 33
      Hello Phil
      I cannot send PM messages.
      Can you contact me?
      • mkarip
        • Feb 2010
        • 33
        That would be the easiest way, but the hard drive is defective, the device cannot complete boot.
        No acces to service mode.
        • mkarip
          • Feb 2010
          • 33
          I have replaced the hard drive, now I have to load system software via USB Device.
          Need Firmware and instruction..Button 2+8 then Download..right?
          • mkarip
            • Feb 2010
            • 33
            I can't select a firmware because I don't have a working USB Flash Drive.
            Get to the screen below, no further.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Was it the correct hdd it has to be supplied by Canon for that series. If you taken from an other machine of the same model you may have to reload firmware on the newer machine Canon are stopping just swapping hdd you will get a 602 error also you need sst to put firmware on a USB look for CTN user copier tech he's website details are on his profile
              Regards Mark
              • copier tech
                • 8141
                Happy to help with the firmware.
                As others have said you can't just fit any HDD to a Canon you have to purchase an identical drive to your failed one.
                • copytech,mike
                  CopyTech,MIKE
                  • Jun 2014
                  • 261
                  You get the firmware VIA Email and copy it to a USB. You dont need any SST for jack. You have to find a Canon dealer who is willing to give you the firmware. Has to be copied on flash drive so that the firmware is at top of the list. Then yes, its power up 28
                  You should find a used HDD from a junked machine and then you wont need the firmware. Without a buddy at a Canon dealer your out of luck. Pay Canon Buis solutions 200.00 to come out with the firware is another option. E602 means that your HDD is dead.
                  • mkarip
                    • Feb 2010
                    • 33
                    Thank you for reply.
                    Is it possible to take HDD from a C355i?
                    • mkarip
                      • Feb 2010
                      • 33
                      Thank you for reply mike
                      • copytech,mike
                        CopyTech,MIKE
                        • Jun 2014
                        • 261
                        No i dont think so because the Firware is probly different. Try calling HYTEC. They might have a HDD with firmware installed on it. Anytime your dealing with firmware your gonna be out of luck without dealer help. You need a used HDD from a C3330i copier. Canon uses the HDD to store the boot up data. This is not the case for lets say a Konica Minolta. Canon uses the HDD to boot up. Other brands only use the HDD to store and scan.
                        • hffyfi77yfw
                          • Dec 2022
                          • 2
                          How to get the firmware please help
                          • copier tech
                            • 8141
                            We're happy to supply this for you. Drop us an email via either link below.
                            • ADV COPIER
                              Pemain
                              • Nov 2022
                              • 253
                              what is your email, I send it
                              Let's Drink our Coffee
                              WhatsApp +62895325228383
