canon 2016 paper jam/change paper size
  • tech12345
    • Mar 2022
    • 3
    hello, i have a problem with Canon ir 2016, paper jam, and appear error change paper size, pickup roller changed, from manual feeder all ok, so sensors may be ok too
    single pages go normally
    thanks all
  • MunsterTech
    • Sep 2014
    • 381
    Re: canon 2016 paper jam/change paper size
    this rings a bell, but a long time since ive seen one, but the registration sensor wears down slightly, you can see it in your pic 2 behind the panel, replace it and it should be good to go again
    • techandtrader
      • Jun 2016
      • 335
      The 2016 and 2020 both had flaws in the engineering of the feed assembly's. Both assembly's saw several revisions of updates as in maybe revision -060! To top it off, to cure the problem, you needed to replace BOTH updated assembly's at the same time. Or else timing problem and jam problem would result. Its dead Jim! Say goodbye.
      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
      • tech12345
        • Mar 2022
        • 3
        that you mean this copier is trash? its not profitable to repair?
          • 23009
          At 16 years old, you probably are not going to be able to find much in the way of replacement parts. Your best chance, I think, is to start collecting Canon imageRunner 2016 corpses, in the hopes of collecting enough parts to fix something. Otherwise, yes, it's time to let it die. =^..^=
          • tech12345
            • Mar 2022
            • 3
            that's right, too much problems with that special one copier which have just 50.000 copies
            usually all that copier need is new drum unit or toner, first case like that
            thanks for answers,
            in free time ill try to do sth with that
            • kasper
              • Feb 2021
              • 3
              - You need to replace registration roller (its called roller vertical path) overtime it become more plastic and slick than rubber
              - When You replacing registration roller, its worth to replace registration sensor black plastic flag just above rollers (the flag rubs off the paper) <- like @MunsterTech said in his post
              • GIUBOSS
                • 1436
                In the rear part of the machine there are also the magnets that activate the rotation of the rollers axis remain glued thanks to the deteriorated shock absorber bearing, replace it with sponge or rubber of the same thickness.
                • mariunciu1
                  • Dec 2013
                  • 4
                  You need replace registration clutch.
