c5045 Dev White Streaks toner carried out. e020-0013 on init
  • techandtrader
    • Jun 2016
    • 330
    [CQ] c5045 Dev White Streaks toner carried out. e020-0013 on init
    So I found the dev unit with big streaks in it. Hoppers do not have dev feed seals. Also found generic drum with signs of HVT problem with bunching up of toner around the front. Replaced it with OEM.
    Replaced Dev - Also found 1 Cya Generic Drum. Replaced it with OEM. Color Mismatch and Auto Gradation passed. Level two shows normal P LED DA =20 So I didnt replace Patch Sensor.
    Cleaned sensor and Normal patch sensor flag operation found. Excellent test page 10. e020-0013 on init Cy Dev ONLY = Reboot and run auto grad = no problem.
    Replace patch sensor is next but hope problem is solved now. I am hoping the HVT is good. Ill have to compare it numbers later.
    I brought the streaked dev unit back to the shop and am curious if I can get it filled again. Have you done that? How?
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: c5045 Dev White Streaks toner carried out. e020-0013 on init
    I have saved old dev units from c7000's c7200's just for the dev to top up units that are low....suppose it is possible on c5000's too
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
