[Canon 5550i] test page is wrong
  • tjrtkdqja123
    Banned User
    • Feb 2022
    • 21
    [Misc] [Canon 5550i] test page is wrong
    Sometimes it's correct , but after 3 or 4 prints there are always gaps like the first photo.
    Thanks for reading, any comments are welcome
    • 23009
    Re: [Canon 5550i] test page is wrong
    I think that I'd start with the primary transfer belt unit.
    How close is it to yield?
    Is it difficult to turn manually?
    If yes, the belt drive or the waste toner drive? Maybe some cleaning would help.
    My guess would be a clogged up primary transfer cleaning unit, dragging down the belt motor drive. =^..^=
    • ElZero
      • Sep 2021
      • 24
      i would start with the cyan drum, switching with other color to test. looks like it's not rotating correctly.
      • Canuck
        Tech Specialist
        • 1713
        If everything checks out mechanically(swap drums, etc), do a REG-CLR in service mode. Reboot then do an auto grad, color correction, etc in user mode
        • wcanonw
          • Aug 2014
          • 404
          Originally posted by tjrtkdqja123
          [ATTACH=CONFIG]56146[/ATTACH][ATTACH=CONFIG]56147[/ATTACH]
          Hello, I sent photos of the test type 6, of the drum unit.
          do maintenance and inspection to the transfer unit (itb belt), then adjustment, init itb, atx-img or mismatch color correction
          • tjrtkdqja123
            Banned User
            • Feb 2022
            • 21
            Thank you all, very very much
            It was T/Bthank you all
