Error: Insert drum cartridge
  • xmen8
    • Mar 2023
    • 9
    [Dead] Error: Insert drum cartridge
    Hello,
    I have had the device for years and it has worked very well so far. Unfortunately, the black drum resulted in a poor print image. Thus, I had to exchange this. After replacing an original drum comes the error "Insert drum cartridge". Now I have read here that a firmware update can be useful. Can someone provide me with the tool and the current firmware? Currently the following is installed:
    9003.7601.4801
    Best regards
  • copier tech
    • 8179
    Re: Error: Insert drum cartridge
    Originally posted by xmen8
    Hello,
    9003.7601.4801
    Best regards
    Which model are you referring to? i'm guessing the IRA C2880 series.
    We can provide this firmware drop us an email via either link below.
    • xmen8
      • Mar 2023
      • 9
      Oh Sorry,
      the Modell is Canon iR C2380i.
      Best regards
      • Qwert01
        • Aug 2022
        • 20
        Hi, I hope I can help.
        • Qwert01
          • Aug 2022
          • 20
          Dcon
          • xmen8
            • Mar 2023
            • 9
            Originally posted by Qwert01
            Dcon
            Hi,
            how can I update the DCon version now? Is there a tutorial or a program to do this?
            Best regards.
            • xmen8
              • Mar 2023
              • 9
              Hi,
              can someone send me the current SST.
              Best regards
              • Qwert01
                • Aug 2022
                • 20
                • tech28
                  • Jun 2013
                  • 434
                  Drum problem, take chip out from old drum, install in new drum, reset drum counter, good to go.
                  • xmen8
                    • Mar 2023
                    • 9
                    Hi,
                    ok, where is the chip an how can i chip out this?
                    Best regards
                    • xmen8
                      • Mar 2023
                      • 9
                      Hi,
                      ok, thanks. Now I have the firmware and the SST. After starting the application, I can't get a connection. I have already registered the firmware. Do I have to use a cross-over cable? Do I have to adjust the IPs in the laptop and also in the SST tool? Sorry for all the questions but Canon makes it really hard.
                      Best regards
                      • tech28
                        • Jun 2013
                        • 434
                        Little chip is right on the drum, just swap then out. Careful not to break it. Over the years, did many times when running into that message. Don't have anymore of those machine's out.
                        Good Luck!
                        I think there might be a little cover that needs to be removed to pop out the chip.
                        • xmen8
                          • Mar 2023
                          • 9
                          Good Luck!
                          OK. I found the chip and replaced it. The counter of the drum was already set to 0. Unfortunately, it still does not work.
                          • xmen8
                            • Mar 2023
                            • 9
                            Hi,
                            Best regards
                            i have found a cross over cable. Set the IP addresses and get a ping. Only unfortunately I get on "Connect" no device displayed.
                            • copier tech
                              • 8179
                              It is easier to create a boot USB pen using the SST then upload the firmware using that (no need to a crossover cable etc)
