IRAC5535i Broken Loop Sensor Arm FC8-5303-000
    • 8142
    [Jamming] IRAC5535i Broken Loop Sensor Arm FC8-5303-000
    Hi all,
    Quick question, what's the easiest / quickest way to access & replace this actuator please? It's not covered in the service manual.
  • GIUBOSS
    • 1431
    Re: IRAC5535i Broken Loop Sensor Arm FC8-5303-000
    Heat a metal paperweight with a gas lighter and push it into the severed part of the sensor, then cut it to 15mm with a wire cutter (for those with patience and a steady hand), good luck.
      • 8142
      Unfortunately the school threw the broken bit away!
      Just wondered what you best way is to access it (new one on order)
      • GIUBOSS
        • 1431
        You don't need the piece of the sensor that was lost, I didn't doubt it, but you would have built the sensor yourself
        • bobburnsreb
          • Mar 2015
          • 232
          Push down where you see my thumb and it will separate.
            • 8142
