Transfer trouble on Canon iR ADV C DX 5840
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Good evening everyone !
    I have an image transfer problem on a Canon iR ADV DX C 5840!
    On the ITB group the printing is perfect, but the problem emerges in the transfer.
    Problem that is present on all 4 colors!
    I replaced the HV board (UN 7).
    The entire transfer assembly present on the door.
    Checked the mass.
    ITB group replaced...
    Nothing !
  • copier tech
    • 8169
    Re: Transfer trouble on Canon iR ADV C DX 5840
    Checked the mass.
    Nothing !
    What do you recommend?[ATTACH=CONFIG]61251[/ATTACH]
    Run that PG10 patten again but a duplex print, does the 2nd side look OK?
    • bobburnsreb
      • Mar 2015
      • 233
      Did you check the values of the service label inside the front cover. Do a P Print and check the values against another machine to see if anything jumps out at you.
      Good Luck!
      • Radiscar
        • Jun 2019
        • 74
        weird paper issue? cold/moisture issue might do something like that.
        I had faded prints on magenta and then it came back on cyan a week after.
        you've probably done this already but run an autogradation before anything else.
        Firmware update
        and you might want to run itb img-x /mmi clear if you run out of options.
        • giogi
          Engineer senior
          • Jan 2016
          • 181
          It could also be the Drum drive or Main controller
          To see the service manuale chap 2 Secondary Transfer Bias Control
          "Knowledge is a source, but unfortunately ignorance is a sea."
