CANON ir c3520 - how to get in to SERVICE MODE?
  • Jedi Ben
    Senior Engineer
    • 77
    hi guys,
    on the new android panel its the 123 key/ head star key/ 2 then 8/ the head star key
    on the older screens i always thought its 123 key/ head star key/ hold 2&8 together then release/ then head star key again?
    both of them dont work on this canon we have taken on from another copier company were looking after it
    my question is - could they of changed the service mode access ??? or my way is the wrong way of doing it
    any help of you Canon Jedi,s would be great
  • bobburnsreb
    • Mar 2015
    • 229
    Re: CANON ir c3520 - how to get in to SERVICE MODE?
    Try performing the following steps. Settings/Registration > Management Settings > Device Management > Settings for Service Representative Access Restriction > set to off.
    Good Luck!
    • Jedi Ben
      Senior Engineer
      • 77
      Good Luck!
      Thank you. Will take a look when i do the rtf on parts. Bit rusty with the Canon kit
      Ben
      • bobburnsreb
        • Mar 2015
        • 229
        Also check Service Mode Login
        COPIR>OPTION>FNC-SW>SVMD-ENT
        0=Default 2 + 8
        1= 4 + 9
        • beaker020
          • Mar 2006
          • 63
          Your second method is almost correct for this model, except you don't need the 123 key. Also, press reset before you start.
          The only thing it may have been changed to 4+9 instead of 2+8.
          Come to think of it, it may be the 123 key that is messing you up.
          • Julian Moore
            • Apr 2025
            • 2
            To enter service mode on the Canon iR C3520, press the * (star) key, then press 2 and 8 at the same time, then press the * (star) key again. This is the standard way. If it doesn’t work, the copier might have a different firmware version or a setting changed by the previous company. Try restarting the machine and repeating the steps, or check if the control panel is a newer version that needs a different method.
            • Larhal
              • 556
              Did you notice that this thread last was commented on in January 2024?
              Larhal
              If all else fails read the Service Manual!
              If that fails, meet me at the pub and we will discuss it.
              • ADV COPIER
                Pemain
                • Nov 2022
                • 249
                Hahaha
                He not read the years
                Let's Drink our Coffee
                WhatsApp +62895325228383
