ir2880
  • kittybo
    ir2880
    i have a ir2880 that does not produce cyan on pronts and copys...i have hoovered out toner supply and it works for approx 1 week then bounces out again...any ideas thanks
  • SCREWTAPE
    • Aug 2025
    Did you try changing the cyan drum. Also is the drum in lock position?
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      We've had 2880's do this...mostly on yellow and black...but each time it was the drum unit.
      • kittybo
        i have changed drum at least twice...still no success
        • SCREWTAPE
          • Aug 2025
          1) Replacing the Develop Sleeve Clutch "CL2" (FM2-3581-000) in the field has resolved the issue.
          2) In this case the replacement of the sub PDRM-EF-A pcb resolved the issue. It was determined that it was the cause by following the steps below:
          1. Re-fit 2 main controller sub PDRM-EF-A PCBs
          2. If the symptom still occurs, interchange the upper and lower main controller sub PDRM-EF-A PCBs .
          3. If the combination of colors that causes the symptom changed from yellow and black to cyan and magenta, suspect a faulty main controller sub PDRM-EF-A PCB and replace the PCB with a new one.
          4. If the symptom does not change after Step2, replace the main controller PCB (main) with a new one.
          FM2-9163 Main Controller PCB Assembly
          FM2-9166 PDRM-EF-A PCB Assembly (S)
          These are two cases in the field. Maybe this helps.
          • kittybo
            thx for help....parts on order will let you know how i get on...
            • Canuck
              Tech Specialist
              • 1713
              There is a problem with these machines on the toner shutters not opening correcly when you engage the process unit handle.....new modified rack. Machine should be giving you E-020 errors if a color is missing
              • kittybo
                thx 4 help...clutch fitted...no probs so far
                • SCREWTAPE
                  • Aug 2025
                  The clutch fixed it?
                  Here are notes from the user guide regarding colors that might not be pick up WHEN USING THE FEEDER!
                  To remedy this problem here is a suggestion:
                  Service Mode>Level 2
                  Copier>Adjust>Misc>ACS-EN2 Set to +2 [Default is +1]
                  Copier>Adjust>Misc>ACS-CNT2 Set to +2 [Default is 0]
