ir2880
  • kittybo
    ir2880
    i have a ir2880 that does not produce cyan on pronts and copys...i have hoovered out toner supply and it works for approx 1 week then bounces out again...any ideas thanks
  • SCREWTAPE
    Did you try changing the cyan drum. Also is the drum in lock position?
    • Oze
      Ricoh Fanboy
      • 1663
      We've had 2880's do this...mostly on yellow and black...but each time it was the drum unit.
      • kittybo
        i have changed drum at least twice...still no success
        • SCREWTAPE
          1) Replacing the Develop Sleeve Clutch "CL2" (FM2-3581-000) in the field has resolved the issue.
          2) In this case the replacement of the sub PDRM-EF-A pcb resolved the issue. It was determined that it was the cause by following the steps below:
          1. Re-fit 2 main controller sub PDRM-EF-A PCBs
          2. If the symptom still occurs, interchange the upper and lower main controller sub PDRM-EF-A PCBs .
          3. If the combination of colors that causes the symptom changed from yellow and black to cyan and magenta, suspect a faulty main controller sub PDRM-EF-A PCB and replace the PCB with a new one.
          4. If the symptom does not change after Step2, replace the main controller PCB (main) with a new one.
          FM2-9163 Main Controller PCB Assembly
          FM2-9166 PDRM-EF-A PCB Assembly (S)
          These are two cases in the field. Maybe this helps.
          • kittybo
            thx for help....parts on order will let you know how i get on...
            • Canuck
              Tech Specialist
              • 1713
              There is a problem with these machines on the toner shutters not opening correcly when you engage the process unit handle.....new modified rack. Machine should be giving you E-020 errors if a color is missing
              • kittybo
                thx 4 help...clutch fitted...no probs so far
                • SCREWTAPE
                  The clutch fixed it?
                  Here are notes from the user guide regarding colors that might not be pick up WHEN USING THE FEEDER!
                  To remedy this problem here is a suggestion:
                  Service Mode>Level 2
                  Copier>Adjust>Misc>ACS-EN2 Set to +2 [Default is +1]
                  Copier>Adjust>Misc>ACS-CNT2 Set to +2 [Default is 0]
