I am going to a 4570 canon tomorrow and this copier is jamming off and on in the fuser unit(wrinkles or creases)its been doing it for awhile.A few techs have been there and cannot seem to figure it out.They have replaced the fuser unit,fuser drive motor.I do not have the jam histroy.I 've had several problems with the right door on this model.Looking for a little help.Thanks
4570 wrinkles paper in fuser unit
Check the flapper fixing delivery, its located on the right side door. If the paper is is jamming in the in the fuser unit and it looks like an accordion or like a fan. Then its trying to deliver but crashes into the flapper fixing delivery, sometimes the flapper doesn't move smoothly. This will rule out the drive motor because its trying to deliver. Since you replaced the fixing unit already, the heat sink is also a culprit when it comes to fuser unit jams.
If you have wrinkles or creases on the copies, replace the pressure roller, bushings and bearings. -
Screwtape.Comment
Guest
Re: 4570 wrinkles paper in fuser unit
When the paper comes out with Z-Fold / Accordion / 3 Fold and jams after several copies with error 0108 Delay in PS14, it means that the fuser film is not rolling with the pressure roller.
Replace fixing film, Remove the old grease (IMPORTANT), Apply Grease and replace film.Comment
