Fuser temp adjustment on a canon IR 330s
  • Machinercylr
    • Dec 2006
    • 73
    Rebuilt a Fuser in a Canon IR 330s and is is causing paper to curl to a point of jamming. Paper was changed and still curled. Is there a simulation that can correct this? Any help would be appreciated.....Steve
  • northerntech
    • Jun 2008
    • 69
    try a better quaility of paper..... try feeding paper upside down.... try lengthwise as opposed to widthwise... there is no temp adj on copier
      • 23010
      Just a consideration...
      It doesn't have to be a fuser problem to cause wavy copies (especially on ledger size prints). The ir330 will produce wavy prints when the internal delivery roller shaft becomes worn.
      Before I went fiddling with fuser temperatures I would be sure the fuser was rebuilt and the exit roller new. Adjusting fuser temperature is a good way to create other problems.
      • roho
        • Mar 2009
        • 844
        Take the fuser out and check it over carefully. Look at the nip, check the inlet guide. Try manually feeding paper thru the assembly as well. Chances are your problem is there.
