Clc 1150 code E061 0070
  • dpepin
    • Dec 2007
    • 51
    Hi to you all!
    I'm stuck with that machine doing that code every morning, things i have done so far. changed primary wire + change grid+ change Drum +
    done a Ram clear + changed the drum ground brush for the one with leaf spring. tried swap the process with a working unit from another
    machine. as for today nothing seems to fix the problem. do you guys
    have another way to fix this, many thaks if you find the way.
    Denis
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5011
    Hi Denis
    try to clean the dust-proof glass and check connectors.Good luck
    • SCREWTAPE
      • Jul 2025
      Check the environmental sensor, AKA the potential control sensor that sits above the drum. You should aslo instead of rewiring replace the primary corona ass'y.
      • dpepin
        • Dec 2007
        • 51
        another guest
        hi thanks for your reply. i forgot to mention that i have already replaced the primary ass'y i took the whole unit from a working machine.
        And screwtape do you mean the potential sensor or the envirement sensor?
        thanks
        Denis
        • waffu22
          • Jun 2009
          • 95
          This problem is seems to mine. Machine iR5000 error 061- 0001. What I'm gonna do is i try to replace the whole unit where drum located and it works. Now i exchange one by one the parts and i know its just the sensor near the drum. Solve
          • etep571190
            • Oct 2009
            • 21
            Hi. I would do two things. If you didn't replace the drum cleaning blade when you replaced the drum do that. But also there is a mirror that needs to be cleaned. I believe its called the foldback mirror.Its between the laser and the drum. Remove all of the panels above the bypass tray and you will see an optics cooling fan. The mirror is located up behind there. Its hard to locate so it might help to find it in the manual first. No one ever cleans this mirror. When its dirty it will effectively lower the laser output. Most of the time primary charge and a new drum fixes that error but when it doesn't I clean this mirror. So far for me it's worked every time.
