Canon Imagepress C1
  • irtek
    • Jun 2009
    • 112
    Canon Imagepress C1
    I'm working on an IPR C1 and it has some white spots in the halftones. The machine just in from a wholesaler with 98k on it, but I can't be sure parts were not swapped. I isolated it to the transfer belt and pulled the ITB unit. There are spots on the transfer belt that match the spots on the copies. They look like pinholes in the belt, not visable holes but like HV arc to the belt. Is this a common problem on this machine? Is there anything I can do to prevent this from happening again? Thanks for any input on this problem.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Its wear and tear. The belt lasts about 70K. This is a high maintenance machine. But it got some good copy qaulity.
    • irtek
      • Jun 2009
      • 112
      Thanks for the information. I was thinking I had read where the belt was rated at 300k but I went back and checked and it is rated for 75K, my bad. thanks for the help.
      • irtek
        • Jun 2009
        • 112
        Is FL2-2576 the correct part # for the transfer belt? Anyone have the part # for the QA kits and what is in the kits? Thanks.
        • charm5496
          • 2387
          Yes that is the correct part number for the ITB belt.
          The kit numbers are F02-5811-000, F02-5812-000, F02-5813-020
          I am not going to type what each one has in them, but we do not use them because of some the useless parts they have in them.
          • irtek
            • Jun 2009
            • 112
            Thanks. My parts supplier said the ITB# has changed to FL2-2584.
            • wtroll
              • May 2008
              • 85
              if you check the related counters of consumables in SERVICE MODE/COUNTERS, you may have the correct situation of any parts and the % of work.
              Don't forget to clear the related counter when you change a part.
                • 16083
                The pit marks are from the arching of the transfer roller to the belt./replace the belt & roller/ clean interior
                this is a high maintenance machine/ u need to set up a PM service sch.on these.
                imagePRESS
                imagePRESS C1
                250K QA Kit
                F02-5813-020
                Part Number Description QTY
                FM2-2496-000 Primary Charging Assembly
                FM2-2495-000 Pre-transfer Charging Assembly
                FC7-0957-000 Ozone Filter (Right)
                FL2-0439-000 Air Filter
                FC6-1392-000 Ozone Filter (Left)
                FC7-0958-000 Toner Filter (Right)
                FC6-9817-000 Toner Filter (Left)
                FC6-9829-000 Toner Filter (Rear)
                FC8-8816-000 Air Filter 1
                FC8-8817-000 Air Filter 2
                FC8-8818-000 Air Filter 3
                FC7-0932-000 External Heating Roller
                FC5-2524-000 Cassette Pick-up Roller
                FC5-1661-000 Secondary Transfer Inside Roller
                C1
                100K QA Kit
                F02-5812-010
                FM2-8070-010 Secondary Transfer Cleaner Unit
                FC5-8829-000 Cleaning Blade
                FL2-2707-010 Seal Support Plate (Front)
                FL2-2708-010 Seal Support Plate (Rear)
                FL2-2709-000 Scoop-up Sheet Support plate
                FL2-2713-000 End Seal (Front)
                FL2-2714-000 End Seal Rear)
                FC5-8837-000 Drum Cleaning Brush
                FL2-6530-000 Fixing Belt
                FM3-1217-000 Pressure Pad Assembly
                FL2-2788-010 Pad Cover
                FC5-9778-000 Fixing Cleaning Belt
                FL2-5453-000 Oil-coating Roller
                FC5-9777-000 External Heating Roller Cleaner
                FC5-9766-000 Steering Roller
                FL2-6048-000 Refresh Roller
                FC7-0175-000 Refresh Heat Insulating Bushing
                25K QA Kit
                F02-5811-000
                FC6-1056-000 Primary Grid Plate
                FL2-2720-000 Pad Holder (Primary)
                FL2-0462-020 Slider (Primary)
                FL2-2720-000 Separation Roller (Manual Feed Tray)
                FL2-0462-020 Slider (Pre-transfer)
                Air Filter 4 (FC6-3482-000) was eliminated from the 250K Kit because the Duct Assembly was eliminated
                from the imagePRESS C1/C1+
