Canon iR2016 Printing problem
  • patil_ps
    • 38
    Hi Freinds,
    My canon iR2016N machine is not printing properly. Also it is not showing Toner Low error on the control panel. But I am not able to understand that if I give a print command, it comes properly & fine. But xerox [copy] of any document is not coming properly. It is printing very light on the left side of the paper. It is happending while xeroxing of the document, not for printing. Please help me what could be the reasong and solution.
    Thanks in advance..
    Pramod
  • patil_ps
    • 38
    Dear All Friends,
    Please do reply for above issue. I am in trouble. I need your help.
    Requesting you to from the bottom of my heart.!!!
    • pinkia
      • May 2009
      • 19
      dear just clean platen glass as its just belong to copy section.
      • patil_ps
        • 38
        Thanks very much for your reply pinkia
        But this problem is not with Glass. This was already done before putting this query to here. I think it could be other issue. therefore if you can help me in this regards & resolve the issue, it will be pleasure for me.
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          If your prints look o.k. and your copies do not, it is not in the print engine, but in the scanner section. I looked in the manual, and I can not find where you would run something like CCD Adjust, like you would in the real copiers. That is why I don't like working on these overgrown fax machines... Too hard to find your way around the system software.
          • patil_ps
            • 38
            Anybody please help me. I am in trouble.
            • jsw2k
              • Oct 2008
              • 95
              Does the problem occur when using the ADF AND when putting original on glass? Have you cleaned the scanner and pickup lens? You may also be able to adjust the scan image density in the service mode.
              • patil_ps
                • 38
                Dear jsw2k
                As you said to adjust the density, i have already made it on full dark [Last]. But still it is giving the problem while taking a copy of document only, not for printing from comp. Also I would like inform you that this machine do not have ADF. This is happening when the paper putting on orginal glass. Now I am requesting you to understand the problem and help me. Also I am reuqetsing you to instruct me how to clean SCANNER and PICKUP lens. So please tell me how to do it. I will do it my sefl as I am doing all maintance or serviing of this machie at my end only with the help of Copytech.
                Thanks in adavnce.
                Waiting for your reply.
                • pinkia
                  • May 2009
                  • 19
                  Can u plz. send me a scan copy of that print. my email id is ashok.chauhan@canon.co.in
                  • patil_ps
                    • 38
                    Thanks ashok.chauhan@canon.co.in for your reply
                    I will mail it you and paste here also.
                    • jsw2k
                      • Oct 2008
                      • 95
                      I have to agree with MrFixIt that your problem is with the scanning. The scanner is the carriage that moves from left to right, with the bright bulb in it. The lens is right there with it. Sometimes dust accumulates on these parts and affects the quality.
                      But I must say that you should be very careful; these things are somewhat delicate and if you don't know what you're doing, you can muck things up pretty good.
                      Failing these, I'm at a loss for what's causing your problems. I would like to see the scan.
                      Thanks..and good luck!
                      • sayednabil
                        • Sep 2009
                        • 72
                        dear ashok
                        you have problem with ur laser unit, once clean the mirror of laser unit, this will work for u...............i am from mum........wt abt u
                        • jsw2k
                          • Oct 2008
                          • 95
                          If he has problem w/ the laser unit, why are the prints OK and the copies not?
                          • patil_ps
                            • 38
                            Dear All,
                            Thanks for valuable replies. I am pasting here the snapshot of scanned copies of printout and xeorx copy of the same printout. Printout is coming properly. But if I take xerox copy of any document, it is not comping proper. Please chek and help me.
                            Thanks in Advance.
                            pramod
                            • apollo
                              • Mar 2008
                              • 191
                              clean your optics take small cover holding copy glass and remove copy glass and carefully clean around scanner unit under copyglass, might have picked up dust.
                              and also clean underside copyglass
