Finally think I got it to work
Here is the pics of B&W and Color banding
The copier was turned off Fri eve
And Monday this showed up with no errors.
After lots of research abd questions
its not the drum
Magenta dev unit was almost empty
Yellow too
I am now looking into the units may have been "over filled "
with toner
The DEV % were way up.
Upon doing a refresh in the Magenta
That color prints and in not in the "band"
the Cyan and K were "full"
Changed the Prim grid and second wires
The image prints some times just fine then this band just shows up!
The B&W was printing perfect, and the color would do this most of the time.
Drum less than 70K
DEV units were refreshed 6K
No leaks
Did see a few error code E0000061-000015
but restarting seemed to stop that
well at least I can post with this pic
thanks guys
need help
restart on the Magenta DEV seemed to get rid of the red on this bane problem
you cam see the red on the color in the pic
now thats gone
this band can move up and down on this image or just not show up at all some times
Just dont think its the drum or the B&W would show the same and the Drum rotation does not match on a full revolution
Almost as if the drum "skips"
its not the drum
Yellow too
with toner
Drum less than 70K
No leaks
thanks guys
need help
now thats gone
