How to Reset Copy Counter in IR Series ?
+ More Options
Posts
    • 23009
    #16
    Thanks Canuck.
    Unethical. It's just unethical to reset counters. You deserve your counter related errors if you are trying to bilk the cutomer into thinking the machine is new, or only slightly used.
    How would you like to buy a copier with 2.5 million copies, that the counter says 125K? I know that I would be PISSED!
    • JustManuals
      • Jan 2006
      • 9838
      #17
      Well,its your own fault for giving these foreigners the information on how to reset the counters!
      Somebody asks on their one and only post and then some moron comes along and posts it.
      Paul@justmanuals.com
      • rajkumar
        #18
        ir3300 reset counter
        Originally posted by zkafs
        U WANNA KNOW HOW TO RESET IR3300 COUNTER I HAVE THE SOLUTION BUT ONLY THRU E-MAIL ONLY zaqmzm@yahoo.com.sg
        please send me the solution thru email (push_vai@yahoo.com)
        with regards
        rajkumar
        • djbass
          • May 2008
          • 167
          #19
          I also can not think of a legitimate reason for resetting the counter, those that are most likely wish to commit fraud.
          I don't think it would work with newer iR's anyway as they are designed to avoid exactly that situation. The counter is duplicated between the counter pcb and the main controller. If you swap just the counter pcb it copies the count info to the new board, and vice verse if you swap the main board it gets copied from the counter pcb, if you swap both boards you get an error.
          No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
          • mitsubee
            • 176
            #20
            Hello , resetting the counter can be done d , using the SST software and a special file that we re-write the counter board data.That special file is also a *.upd file that run compatible on SST.Just throw into the machine it`s under SYSTEM v43.01.
            • zkafs
              • Jun 2007
              • 29
              #21
              pls forget it
              • _SuabE_
                • Jan 2008
                • 108
                #22
                If you want to RESET Counter for Canon IR Series, Let me Reset for you
                sigpic
                Senior Technician Specialist
                A+; Network+
                Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
                Printer Handled: Canon, HP, Epson, Brother, Samsung
                Duplicators: Risograph, Duplo
                • 555
                  • Jun 2008
                  • 45
                  #23
                  jacking with the counter is a good way to nuke the whole machine. dont do it unless you want to use it as a doner
                  • ben-copier
                    • Feb 2007
                    • 19
                    #24
                    If you're to purchase from other sources, they'll be no updates for future upgrades In order for updates & future updates, please visit www.bootrom.biz
                    We have received many of request updates that theyโ€™re bought from other sources. But we've denied because they just hit & run. Get your money and just disappeared.
                    Just to remind any of their customers, please be aware. You never get any updates from them after you've transfer your money.
                    • haydar64
                      #25
                      Helle, can u share again this file?
                      Thanks a lot.
                      HAYDAR64
                      • thenappan
                        • Mar 2009
                        • 10
                        #26
                        reset
                        hi
                        can u tell me how to reset and where i can get the software
                        thanks in advance
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          #27
                          So far as I'm aware there are only chip resetters availabe for Oce,KM and Ricoh.
                          There are no resetters available for Canon boxes to the best of my knowledge.
                          • mtech
                            • Mar 2007
                            • 307
                            #28
                            Resetting counters? Where are your ethics? The biggest reason to RESET a counter is to deceive. You can always find a way to compensate for variances. Bad Karma. Nothing good will come of it.
                            • mitsubee
                              • 176
                              #29
                              Bro Oze. for canon ir-series e-counter can be reset no need any chips..... file name 0000000.upd the is the file that u throw in using SST.that`s it....all counter will go Zero.
                              • thenappan
                                • Mar 2009
                                • 10
                                #30
                                file
                                dear mitsubee
                                where can i get that *.upd file to download to the ir series machines
                                thanks
