ir2270 3570 4570 fuser Anyone rebuilding these, if so care to pass on secrets ?
  • Simons
    • Jun 2008
    • 490
    I think its cheaper and alot less worry and work to send these back to canon for rebuild. I have heard of several people fail trying to refurb them in shop.
    I thought it would be fun to hear from any of you that have mastered it 100% correct.
  • teckat
    • 16083
    i think u can replace the pressure roller with no problem
    • SCREWTAPE
      East Coast Imaging
      • 3396
      These can be rebuild, 15 to 20 minutes
      I do it all the time Parts like, fixing film, pressure roller, bushings are all that need to be replaced.
      I had to do one today.
      After 500k to 700k then you can consider replacing the whole unit.
      There are no secrets.
      • kuby
        • Oct 2007
        • 1409
        Yea, I rebuilt 3 this month. Worked Great.
        • costd
          • Jan 2008
          • 409
          We had a real QC problem with rebuilt units from Canon so I was rebuilding these (except we bought rebuilt film units) until we found TSA could sell us a rebuilt unit for $6 (including shipping) over the price we pay for just the parts (not including my time). No spamming. TSA has done well by us - your milage may vary.
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            I agree with all the others here,,, the rebuild is no big deal, fix film assembly, is all I replace on most of them. When they get long in the tooth, then the pressure roller and bushings,, also don't forget the clean roller. You can use the 2200 clean roller, just pull it out of it's frame.
            • Simons
              • Jun 2008
              • 490
              Well ill be a son of whiskey barrel. I still would like to hear about costd detailed experience with using that SIX DOLLAR film from TSA. thanks!
                • 23009
                Simon,
                I think you read that wrong. The way I read that past was:
                parts cost + $6 = cost of TSA refurbished fuser
                Personally I have a hard time believing that since the parts total for one of these rebuilds is $65.00 (including shipping).
                This is not to impune TSA World in any way. They provide great service and stock a wide variety of parts that I can't get anywhere else. prntrfxr, anything to say?
                • costd
                  • Jan 2008
                  • 409
                  Blackcat - I guess you use a different supplier as our parts cost for a complete rebuild including a rebuilt film is much higher than that. Then again, we are were to getting our rebuilt fixing film assemblies from Canon. If by rebuild someone means just the fixing film - that is not a complete rebuild.
                  On the other hand, I am very open to suggestions on where I can obtain all the parts for a complete rebuild for $65 as times are really hard and we could save big bucks.
                  Not trying to start a war of how many times someone keeps the same bushing, pressure roller, etc. We also try not to replace parts that do not need it, but in my short time as a tech I have not seen many pressure rollers that go 480K.
                  A number of you guys have been around a lot longer than I have and if you know a few tricks (like Mrfixit suggesting the 2200 cleaning roller at half the cost) I am ready to take notes and give credit. Really, I want to learn.
                    • 23009
                    At 150K, that $65 includes:
                    Fixing Film
                    Pressure Roller (I'm happy with 150K)
                    Heat Sink Roller
                    Right Door Latch
                    PR Bearings adds $8 at 300K
                    There's an incremental cost for fixing film lubricant. The film comes with a teeny little packet that is nearly half of what you need. Add a few more cents, lets say $0.10 each.
                    • costd
                      • Jan 2008
                      • 409
                      Thanks for the info. We have to purchase the rebuilt film assembly as I have been told it takes special equipment - and my talent falls short. Don't know why it seems to me 240K was right and have been bummed I can only get about 210 or so even though I replace the heat sink every time I do a drum.
                      Thanks again for the info. I may try rebuilding again and see how far replacing just the fixing assembly gets me. Will cost more than 65, but a lot less than what we pay now.
                        Special equipment ? I've fitted a few of these films and so long as you get the fixing film home position patch on the right way round you wont have any problems.
                        • costd
                          • Jan 2008
                          • 409
                          Maybe I should give it a try. Nothing to lose. Is this for e0007 only or just a film for the e0001/0002/0003 codes also (my most common codes)? Actually I usually just try to reset a 0001 if I can.
