iR5000 blank
  • bakaoni666
    • Mar 2010
    • 56
    iR5000 blank
    iR5000 has a blank print.
    it was happen after jammed on the middle of registration roller.
    i've already change DC Con, R Con, M Board, Unit 1, HVT, All Corona, Developing, Laser, CCD unit...
    Any ideas...
  • bakaoni666
    • Mar 2010
    • 56
    Sorry It was iR5000i
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Any ideas...
      Pontential control, have you look at that.
      • bakaoni666
        • Mar 2010
        • 56
        i change the upper part of the machine...( RCon, Scanner, PO Cont, Laser, CCD, Lens.)
        I've alredy Clear all the program. (Function--Clear--Err, etc)
        any other ideas..
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Did you try jamming up the machine to see if any images are form on the drum???
          One more ? I've should've ask before..
          Do you print to this machine.
          Is this just happening from the glass.
          You change a lot of things in the R-Con area.
          If this is happening from the glass then I would understand why things were change at R-Con.
            • 16083
            Any ideas...
            your machine was working fine until u had a jam ??
            why did u change all those parts ?? / did printer loose power when it jammed / what was jam code/ any error codes ?? scanning / copying or printing
            • MrB
              • Nov 2009
              • 147
              Mr B is with Screwtape on this on e with Pontential control
              I had this witha 5055, and tried a new PC, and got a solid black page
              Turned out that the PC i fitted was faulty (was 2nd hand grrrrr)
              2nd on was new, and fixed it
              FG6-5080
              • bobthecopierman
                • Mar 2010
                • 53
                Does it have a scan lamp? Most canon models will print blanks after the scan lamp blows and the machine is power cycled.
                Just a thought.
                • anothertech
                  • 1769
                  Have you checked VD(voltage in the Dark area)and VL(voltage in the light area) in service mode?
                  This sounds like a fun one, I wish I was on site. Troubleshooting through a forum is not so easy.
                  • Dedy.P
                    • 67
                    Try changing the potential board and potential reader. check the wiring for any fault
                      • 16083
                      Orig poster bakaoni666
                      is MIA (?
                      • bakaoni666
                        • Mar 2010
                        • 56
                        you're right it was the bias cable. thanks.
                        are u from jakarta. i'm novel. i come from malang. nice to meet u.
                        • kaushikviral
                          Any ideas...
                          chek the right sidedoor swich
                          • smiley
                            • Aug 2008
                            • 615
                            hi try if the unit one transfer separation assy. is going up or down evry time you insert and lock the unit one.
                            there is no glory without sacrifice
                            • montana
                              • Aug 2008
                              • 392
                              hi...check the drum rotation is it ok?also you should make test print
