I keep getting E000100-0001. Laser is fine and I replaced the DC Controller, any additional suggestions would be greatly appreciated.
Thank you
did u Re Flash the Dcon after replacing DC CONTROLLER ???? also did u remove or service the Registration Assembly/ if so check grounding tabs.
Check the H.V. Resistor contacts to make sure they are secured and not broken. Also check grounding plates on metal registration roller, only the operator side tab should be touching the roller and the non-operator side should be in contact with the upper guide plate. IMG_01841..jpg IMG_01791..jpg
Yes I did that also. But I just checked the shutter and even though it moves freely I think that is where the problem is. I moved it by hand when I hit the print button and noticed it hesitated just a little bit, but then I got copies out. So that is where the problem is at the moment. Thanks for the help and advice.
Chris
Exactly. if it hesitates remove it and check for broken pieces
Also check the leaf spring. Here's a shot.
