E000064-0000 canon ir3300 error result
  • kkwong0209
    • 45
    I face thos problem. how to solve it?
  • kuby
    • Oct 2007
    • 1409
    Check power supply - replace if necessary..
    E064 Power supply voltage error
    (high-voltage error)
    • teckat
      • 16083
      to add on to kuby's response also>
      Make sure the Developing bias value is set incorrectly.
      Check the setting of COPIER>ADJUST>DEVELOP>DE-DC in service mode. Compare this value with that of the service label. If the setting is found to be out of adjustment, set the value back to door specifications. After making the adjustments, run some continuous copies to check for occurrence of the code. Since this value is maintained by the DCON the same adjustment is required after replacement of the DC controller.
      • Canuck
        Tech Specialist
        • 1713
        Make sure that the transfer roller hasn't popped out of place
        • teckat
          • 16083
          to add on
          Check that the Pressure Plates (Leaf Springs) for the Transport Section are in good condition and making good contact with the Transport Bed.leaf..jpg
          • davidj7
            • 1107
            i ve had to replace transfer roller for this issue couple of times.
            a machine is only as good as your tech : source:screwtape ; the scary one
            • bahgat mohamed
              • Jun 2009
              • 17
              if the drum leaks it also makes E64 ,so replace it if deteriorated.
