ir1023 lead edge way off
  • Albonline
    • Sep 2008
    • 1151
    have replaced the image processor board. lead edge sensor. reflased the machine. any help anybody?
  • charm5496
    • 2387
    are the margins the same from prints, faxes and copies?
    You may need to get into service mode and the lead edge margin. If it is from copy only then you need to adjust the scan start position.
    • Albonline
      • Sep 2008
      • 1151
      all outputs are about .5 inch early . also when running 8.5 x 11 it says to add 8.5x11 after each page output.
      • charm5496
        • 2387
        check the sensor flag for the add paper sensor isn't bent and that it moves properly to interrupt the sensor.
        The parts are listed in Figure 310
        #17 IC, Photo-Interrupter (Sensor SR9) = WG8-5776-000
        #5 Sensor Flag Flag = FC6-7366-000
        also check and make sure this is set correctly Additional Functions > Copy Settings - Paper Size Group is set to Inches.
