IR105, jam code 010B
  • addoncopier
    • Feb 2010
    • 114
    Need help, what is the problem to do with this code in IR105 010B...Registration also Run Out, "
    1st page very left, 2nd page very right...."
    • 16083
    delay jam to the Inside Delivery Sensor PS9.
    can be caused by a broken 52T gear found on the upper fuser roller
    Check the Paper Pickup Drive Assembly, or the Pickup Motor M2. A malfunction in this area, such as M2 running slow may cause a registration problem and possibly an 010B jam code.
    • 20YRSEXP
      • 281
      Definately sounds like a paper movement issue. Check the registration clutch and clutch housing. make sure the housing isn't broken and the clutch is in good shape. Try cleaning it.
      Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
      • Canuck
        Tech Specialist
        • 1713
        definitely...especially if wandering registration. If you were getting delay jams at reg or prereg sensor maybe pickup motor...doubt it though...lead edge reg is determined by clutch off/on....turned on by signal from reg sensor. The housings break and the clutch is not anchored properly
        • addoncopier
          • Feb 2010
          • 114
          Teckat,What is the problem of IR105 jam code 0205,0209..
            • 16083
            02xx is stationary jam code
            0209 = check paper deck/Brake Clutch wiring connection
            0205 = think it's a vertical path issue
            • addoncopier
              • Feb 2010
              • 114
              By the way, any machine to suggest if i want to do for storage. Scan and U-send the book to computer is it possible? Tired of scaning master copy.
