iR-c5180 Error E674-008
  • Bill Agudelo
    • Jul 2009
    • 16
    I just installed this Fax-board on this working iR-c5180 but get error E674-008. I can't figure out what could be wrong.
    I found one connector at the bottom and three connectors at the top. Only thing I notice is that there is a(fourth) three-pin connector (two wires) on the top, that doesn't go anywhere. Could I be missing something?
    Please help.
  • Bill Agudelo
    • Jul 2009
    • 16
    Does it need a Resolution-board also?
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Try removing and reseating the connector for J260 on the fax board. The connection to J260 is a 2 pin harness with blue and orange wires.
      If reseating J260 does not solve this, you may try a main controller clear. Before doing a main controller clear, print out the service mode settings.
      Enter service mode level 1 and print out the service mode settings (COPIER>FUNCTION>MISC-P>P-PRINT).
      Also note this will also clear any Mail Boxes and any User Data.
      Then press (COPIER>FUNCTION>CLEAR>MN-CON) select MN-CON then press OK.
      • charm5496
        • 2387
        a resolution switching board is not needed. Screwtaps advice is spot on!!!
        • Bill Agudelo
          • Jul 2009
          • 16
          SCREWTAPE,
          I did what you suggested, but still get the same code.
          However, if I do an error->clear, the display comes back immediately and looks normal; I can see the fax function now. However, the display responds weird and, if I turn the copier off, the machine goes off but the display remains on.
          Finally I have not choice but to restart the copier from the master switch. Then the code comes back and I am back to square one.
          Do I need to update the system software? Now the machine has 52.01 for DC-CON and 51.01 for BOOTROM.
          Bill
          • SCREWTAPE
            East Coast Imaging
            • 3396
            I would try upgrading at this point.
            Your machine is behind. The latest is 92.06
            • Bill Agudelo
              • Jul 2009
              • 16
              I do not have the latest system software for this iR-c5180.
              Does anyone have it?
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Your gonna need SST too.
                Do you know how to upgrade machines?
                Can you verified which fax kit you installed into the machine.
                • teckat
                  • 16083
                  check your PM
                  You also need to install _an additional 512 mb Expansion Ram in the 5180 for Faxing_Canon Color Universal Send Kit_Color UFR II/PCL Printer Kit_Color PS Printer Kit_
                  Color PCL/PS Printer Kit_Color UFR II/PCL Printer Kit_ Color UFR II Printer Kit_Direct Printing Kit_Color UFR II/PCL/PS Printer Kit_Color UFR II/PCL Printer Kit_Color UFR II Printer Kit
                  u should have 1024 MB Ram in this 5180/ check on control panel
                  Super G3 Needs the extra Ram/ not sure about the G3_V1
                  These are the Newer Fax Boards for your machine>
                  SuperG3_V3
                  or SuperG3_Multi Line_H3
                  or did u install a older G3 Fax Board_V1
                  • teckat
                    • 16083
                    Just to add>for iR-c5180 Error E674-008
                    Make sure u have installed the correct Fax for this model !!!!!
                    Check and re-seat the ribbon cables located inside the G3 fax
                    Check the cable between the fax and Main Controller and the power connector/It is easy for this connector to be partially inserted on either side, ensure it is fully inserted.
                    • charm5496
                      • 2387
                      Originally posted by teckat
                      check your PM
                      SuperG3_V3
                      You do not need the 512 MB RAM for universal send (this is standard on the machine) or the fax board for this model. All you need the 512 MB RAM for is the PS kit to expand the memory for printing.
                      • teckat
                        • 16083
                        Your right, I forgot they updated that service manual mistake in '07
                        • Bill Agudelo
                          • Jul 2009
                          • 16
                          I did install the latest firmware: 66.01 for DC-CON and 51.01 for BOOTROM. (Is this the latest?) I still get E674-008.
                          The machine has 1536-MB of RAM.; Universal Send; Print PS/PCL/UFR-II.
                          I do not know which fax board I have, the control panel shows "????ONBOARD FAX" How can I tell?
                          Thanks for your help.
                          • teckat
                            • 16083
                            where did you get this Fax Board From ??
                            Was it Boxed ??
                            First Remove Fax Board- then upgrade 5180- then put back Fax Board.
                            if correct Fax Board is installed/ should work
                            Your System Software and Language must be same version/
                            If u have v92.06 u need to install all the Firmware / using SST-Select iRC5185 V3- highlight ALL/ Download to machine. Do not pic and choose what Firmware to download .
                            • teckat
                              • 16083
                              <Version check>
                              COPIER > DISPLAY > VERSION > FAX
                              When Fax Board-V1 (*1) is equipped, "On Board -F+” is
                              displayed.
                              When Fax Board-V2 (*1) is equipped, "On Board -D" is
                              displayed.
                              (Option configuration screen shows V1/V2 (*1), but you can
                              check which Fax Board is equipped using the service mode.)
