irc 5870 very light copy
  • smiley
    • Aug 2008
    • 615
    [CQ] irc 5870 very light copy
    hi guys any idea can you share with me.my 5870 the print is too light in all colors i hve replace the primary charge corona with no help.any idea please.
    there is no glory without sacrifice
  • SCREWTAPE
    East Coast Imaging
    • 3396
    You can try the transfer roller.
    • smiley
      • Aug 2008
      • 615
      the image cannot be see just a shadow that is too light.you mean i have to replace the transfer roller?
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Try replacing the transfer roller.
        Its doing this in all colors you said..
        There are other factors however.
        • smiley
          • Aug 2008
          • 615
          what are does factor aside from transfer roller?
          • smiley
            • Aug 2008
            • 615
            i replace the transfer roller but still no improvement.
            • teckat
              • 16083
              post a copy of issue
              • smiley
                • Aug 2008
                • 615
                this is the semple of pg 10.
                Last edited by smiley; 06-19-2010, 05:18 AM. Reason: i cant post the sample picture
                • smiley
                  • Aug 2008
                  • 615
                  its look like no print.
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    When did this occur?
                    What has been done for service in the last 6 months?
                    What is the meter count?
                    • smiley
                      • Aug 2008
                      • 615
                      its about 700k. the transfer belt has been replace corona wires.
                      • blazebusiness
                        SanDiegoCopierRepair.com
                        • 1257
                        The first thing I would do to diagnose this is stop the image in the ITB to see if it looks good. If the image on the itb is ok then the secondary xfer roller or some other xfer issue is happening. Poor xfer can also be caused by bad HVT assembly. but you need to first determine if it is a bad xfer issue or not. If your image on the itb is bad you need to focus on the primary corona for starters or maybe primary transfer roller assembly. You said you replaced the primary corona. Did you replace the whole corona assembly? Or just the wires? Did this problem occur after somebody tried to rebuild the corona?
                        • SCREWTAPE
                          East Coast Imaging
                          • 3396
                          What about the bias clips on the ItB ass'y.
                          • teckat
                            • 16083
                            you first {quoted}the print is too light in all colors
                            now your say pg10 is blank ??
                            Blank & too light - what is it ??
                            have u tested copies of glass ?
                            keep it simple/ is their an image on the ITB belt ???
                            *****make sure the ITB cleaning blade is not staying engaged
                            is the primary transfer roller locked in position
                            • SCREWTAPE
                              East Coast Imaging
                              • 3396
                              is the primary transfer roller locked in position.??
                              [ATTACH=CONFIG]5022[/ATTACH]
                              The primary transfer locking mech.
                              Good point!
