hi guys any idea can you share with me.my 5870 the print is too light in all colors i hve replace the primary charge corona with no help.any idea please.
irc 5870 very light copy
Tags: 5870, 870, address book, affects, belt, boot, charge, control panel, copy, corona, count, dc controller, diagnose, factory mode, good, help, hvt, image, irc, issue, light, meter, meter count, occur, primary, print, pushed, replace, roller, secondary, service, shadow, share, transfer, unknown, wires, wrong
The first thing I would do to diagnose this is stop the image in the ITB to see if it looks good. If the image on the itb is ok then the secondary xfer roller or some other xfer issue is happening. Poor xfer can also be caused by bad HVT assembly. but you need to first determine if it is a bad xfer issue or not. If your image on the itb is bad you need to focus on the primary corona for starters or maybe primary transfer roller assembly. You said you replaced the primary corona. Did you replace the whole corona assembly? Or just the wires? Did this problem occur after somebody tried to rebuild the corona?sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
you first {quoted}the print is too light in all colors
now your say pg10 is blank ??
Blank & too light - what is it ??
have u tested copies of glass ?
keep it simple/ is their an image on the ITB belt ???
*****make sure the ITB cleaning blade is not staying engaged
is the primary transfer roller locked in position.??
Release..jpgLast edited by teckat; 06-20-2010, 04:59 AM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
