canon wont go to ready.fuser heats up no error message . stays at please wait .
try disconnecting the Finisher. If the imageRUNNER will come to ready with the Finisher disconnected there may be a fault in communication with the Finisher, even though no error code is indicated.
Check to see if the Staple Cartridge is properly seated. It has been found if the Cartridge is not fully seated in the Stapler the above symptoms may be observed.
also check that the finisher has not run out of staples or the staple cartridge is missing or not properly installed.
Normally something like this is related to the finisher which is why the other guys had you start there. You stated no finisher so go next and Check the fixing feeder frame connector. Also-is there paper behind the Fixing feeder frame assy? Have you checked the error history in service mode?
