Canon ir3200 & imagepass c1
  • bcoots
    • Aug 2025
    Hello everyone. First I'd like to say, nice forum, and I am glad I ran across this place. I have came a long way just by reading a couple post here that have helped in clearing the air about our "new to us" Canon 3200. When I first got it, I didn't even know what that "box hang'n off the back" was. This is our first copier, and boy was I struggling. Now that I've read, and studied, I have determined that the box on the back is in fact a C1.
    I have read both of these threads, both from copytech forums.
    http://www.copytechnet.com/forums/ca...network-4.html
    and
    http://www.copytechnet.com/forums/ca...ng-me-off.html
    I will give you the run down of what I have done so far. First thing we did when we got the machine was clear everything. We did this via going to service mode, copier, functions, clear, and clearing everything that we could, and we did the MN-CON clear last.
    That being done, I went into Service Mode, INT-Face, IMG-CONT and changing the number from 0 to 3. Restart the machine when it boots, I have the "Scan / Print" button now at the top right of the touch pad.
    When I go to this tab, I get two options... the option on the left is "Remote Scanner" option on the right is "Printer". From what I've read, I should click on Printer on the right and be able to go into Functions and Run Setup. Instead I get this message that says:
    "Wait a moment. Check the power source of the print server behind the main unit and the cable connection if the display does not change in a moment."
    I have no idea what is wrong with it, the power cable is plugged in fine, and I've got a crossover cable from the card on the copier to the top port of the C1. Is there a way to test and see if the C1 is talking with the copier?
    Anyway, this is where I am and I would greatly appreciate anyones help solving this issue and getting this baby to print via network. Hope everyone has a good day. -Brad
  • SCREWTAPE
    East Coast Imaging
    • 3396
    MN-CON should not have been cleared!
    Chance's are firmware might have to be reloaded on to the machine and C1.
    There's a panel that's located on the inside front cover of the machine that should have a sheet of some service mode values.
    I would have someone who is certified to trouble shoot out your issue if I was you.
    Do not make more of a mess of things.
    • teckat
      • 16083
      what about your Network Cable/ is your Interface cable plugged in from C1 to 3200 ??
      You better find those P Print Data sheets, if u cleared DCON & RCON u at least need those orig. numbers put back in.
      why did u clear all that information ???? it makes no sense ~~~~~~~~~
      where did you or why would you buy an imageRunner 3200 with a C1 imagePass , without any knowledge of the options and operations
      of this unit.
      Best bet is to call for service , ask for a trained tech. with network knowledge on your model
      • bcoots
        Well, one of the salesmen that work at our office knew a "canon tech" that he used to work with and he assured us that he knew what he was doing.. the "tech" is the one that gave us the instructions on "clearing" everything before we even got started hooking it up. Told us to clear everything and then put in our data. When I get to the office in the morning, I will make you a list of everything that was "cleared" in the service mode option. I can tell that this is serious, and I do apologize for my ignorance. You asked why I bought it with no knowledge of the copier / c1... well I didn't buy it, it was bought by my office and I am simply the "Network, Hey boy" guy around the office and was told to fix it. So here I am.... arms in the air I suppose. I do appreciate your replies. Also, which numbers do I need to go into service mode and look at to see if they have been cleared?
        My list for tomorrow so I will understand correctly is to
        1. Find the numbers on the P Print printout in the front inside panel of the machine. (Any specific area I am looking for that the sheets usually are located, does front inside cover mean behind the drawers etc?)
        I mean, I'm willing to learn, and follow instructions step-by-step, but from the sound of what you two are telling me, there's a slim chance that I'll get this up and running. At this point, I don't know if my Boss is willing to call in tech. support... so right now I'm on the front lines.
        Thanks again for your help / support.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Tomorrow just hook up everything up. Its good that you see the printer tab, that means the 3200 is aware that there is a imagePass hook up to it. At least that part of the configuration is set up correctly. That tech is thinking ass backwards. You should print out a P-Print before clearing anything, that's protocol!!
          I wouldn't even let him touch the machine!
          If it still shows the message make sure that.
          1. Make sure Img-Cont is set to 3 in service mode Copier/Option/Int-Face. Which this is done>>
          2. Make sure the DIP switches on the imagePass are both in the down position. There is a little cut out hole on the imagepass C1, two little switches.
          3. Check the cables used to connect the imagePass to the copier. There are two cables that come with the imagePass, one a cross over cable and the other a regular patch cable. The cross over cable is shorter than the patch cable.
          4. Try reinstalling system software on the ImagePass C1. Next try refreshing the main unit to the latest firmware.
          Tell your boss to consider having a trained Canon service representative fix up that problem.
          Good luck.
          • teckat
            • 16083
            Open Front door , look under that cover in picture, if they are not there u will have issues and a big headache .
            Then:
            u need to get back in service mode
            1) Press the asterisk key (
            *) on the operation panel.
            2) Press 2 and 8 simultaneously on the numeric keypad.
            3) Press the asterisk key (*) on the operation panel.
            SELECT>COPIER>DISPLAY
            screen will show those seven tabs below >
            Display- I/O- Adjust- Function- Option- Test- Counter
            most of the P Print Data needs to be input under -ADJUST TAB
            under ADJUST you will see EIGHT TABS listed below
            ADJ-XY
            CCD
            IMG-REG
            LASER
            BLANK
            FEED-ADJ
            CST-ADT
            MISC
            This is where most of those Signals from P Print Data sheets need to be input
            under CCD TAB is the RCON #'s for the (READER), if u did not clear RCON don't worry about this,
            Under rest of TABS u just highlight to check the P Print readings against machine readings, if machine readings differ, input what is on sheets
            I/O= Tab is for checking signals & operations
            FUNCTION = Tab is a (operation/inspection mode)
            You will need to put in the IMG-CONT= 3 setting
            also if u have a DECK , u need to put in under ACC Tab=DK-P, your deck paper setting
            Used to set paper size used by paper deck (option).
            Setting
            0: A4 (value at time of factory shipment)
            values
            1: B5
            2: LTR
            These Tabs below are for viewing machine information
            VERSION
            USER
            ACC-STS
            ANALOG
            JAM
            ERR ALARM-2
            DENS
            MISC
            THIS IS WHAT THOSE CLEAR SETTINGS DO/ or DID >>>>
            <CLEAR>
            Used to clear RAM, error codes, jam history or error code history.
            ERR
            Clears error codes.
            (Cleared error codes: E000, E001, E002, E003, E719)
            Operation 1) Select this item, and press the OK key.
            method 2) Turn the main power OFF/ON.
            DC-CON
            Clears DC controller PCB’s RAM.
            Caution The RAM is cleared after the main power switch is turned OFF/ON.
            Operation 1) Select COPIER > FUNCTION > MISC-P > P-PRINT to print out the
            method service mode setting values.
            2) Select this item, then press the OK key.
            3) Turn the main power OFF/ON.
            4) Enter the data printed by the P-PRINT operation as needed.
            R-CON
            Clears reader controller PCB’s RAM.
            JAM-HIST
            Clears jam history.
            Caution The jam history is cleared after the main power switch is turned OFF/ON.
            Operation 1) Select this item, then press the OK key.
            ERR-HIST
            Clears error code history.
            Caution The error code history is cleared after the main power switch is turned OFF/
            ON.
            PWD-CLR
            Clears “system administrator” password set in user mode.
            Caution The password value is cleared after the main power switch is turned OFF/
            ON.
            ADRS-BK
            Clears address book data.
            Caution The address book data is cleared after the main power switch is turned
            OFF/ON.
            CNT-MCON
            Clears service counters maintained by main controller PCB (main). (See the
            COUNTER mode items for the counters cleared.)
            Caution The counter values are cleared after the main power switch is turned OFF/
            ON.
            CNT-DCON
            Clears following service counters maintained by DC controller PCB:
            • COPIER > COUNTER > DRBL-2 > SORT
            • COPIER > COUNTER > DRBL-2 > FIN-STPR
            • COPIER > COUNTER > DRBL-2 > FIN-PDDL
            • COPIER > COUNTER > DRBL-2 > SADDLE
            • COPIER > COUNTER > DRBL-2 > SDL-STPL
            ON.
            OPTION
            Restores OPTION service mode setting values to default values (RAM clear
            values).
            Caution The setting values are cleared after the main power switch is turned OFF/
            ON.
            Note The cleared data is the data in the main controller, DC controller and reader
            controller.
            MMI
            Clears following user mode setting values:
            • Backup data for copy operation panel (user-set values)
            • Common settings backup data (user-set values)
            • Backup data (except fax data) (user-set values)
            ON.
            MN-CON
            Clears RAM on main controller PCB’s SRAM board.
            Caution • The RAM is cleared after the OK key is pressed.
            • Executing this item initializes all the data on the SRAM board. In other
            words, file management information for the hard disk is initialized, and
            image data on the hard disk can no longer be read. Before executing this
            item, explain to the user that all images in the BOX will be lost, and receive
            permission to execute.
            • blazebusiness
              SanDiegoCopierRepair.com
              • 1257
              If one more voice from the choir will help convince you - I cannot emphasize strongly enough that at this point you should stop all efforts you are making and follow Tekcats and Screwtapes direction and call for a trained Canon Rep. Thats the best advice-----be smart enough to take it.
              PS I'm not quick to criticize others but a lot of people will call themselves a "Canon Tech" and may have little or no formal training with the Brand.
              • bcoots
                1. Checked to make sure, it is set to 3.
                2. I will upload a picture of my imagepass, but looking over the C1, I do not see the DIP Switches. On one side (left hand side if you're looking at the back of the copier) is two fans, the power switch and power cord. (Right hand side) I've got the top Ethernet Port, the bottom ethernet port, another type of port (looks like a big serial type port), and that's all. top side has nothing, bottom side has the serial numbers etc. sticker and that's it. Above the top ethernet port on the right hand side is a cut out, but it's empty... no switches to be found there.
                3. Got a cross-over cable that I hand built myself, and I know that works, because I've tested it with a direct connection to another machine and setup a LAN, and everything worked properly, going from the top ethernet port, to the copier NIC. Got a straight cable going from the bottom ethernet port, to my router.
                4. When we got the copier, there were no manuals, and no cd's that came with it. So unless I can download the firmware, and the imagepass software, I will be out of luck with this step.
                Thank you for the picture, that helped a lot. There were no manuals, or no p print outs in the cupboard door there. I opened the box that looked like it would contain the papers by removing the two screws and lifting the box lid open, nothing there.
                If I had the papers I would continue to go with the rest of your steps... but apparently I cannot do such things without the proper paperwork.
                The problem with having to call a canon tech. is that I live in a small rural town in Alabama, and as you can tell, we apprently have a lot of shade tree canon tech's running around. I'm sure this will be quite an expensive venture to get done.
                Is there any numbers or anything I can write to y'all and tell me if the settings and everything have been cleared out of the machine that need to be put back on? I can do a p print and tell you the boot loader #'s etc. Thanks again for all of y'alls help. It is greatly appreciated.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  The best way to start, is to really call a pro.
                  It sucks but, It might be your best option.
                  You can do a lot of searching thru out the forum to help you out but, with out the right things you need like, firmware your gonna have a hard time.
                  Your situation is a little grim right now.
                  • bcoots
                    K, I went into service mode > Display > Version > ....
                    Dcon - 10.02
                    Rcon - 04.01
                    Panel - 00.02
                    Eco - 41.08
                    feeder - 4.01
                    sorter - 4.01
                    fax - --.--
                    NIB - 04.00
                    PS/PCL - --.--
                    Lips - --.--
                    SDL- STCH - 03.01
                    OP-COn - 02.02
                    MN- CONT 10.01
                    Boot Rom - 04.10C
                    Diag - DVC - --.--
                    RUI - 09.03
                    Lang EN, FR, DE, IT, JP - 10.01
                    GDI-UFR --.--
                    If there is anything else I can lookup and give, please let me know.
                    • bcoots
                      Well, I do appreciate all the advice then. I talked to Canon, and there is only 1 Canon Tech in my area. I know the guy, and boy this isn't good. The closest major city to me in 40 miles away. Calling in a tech. is going to be down right expensive I have a feeling.
                      • SCREWTAPE
                        East Coast Imaging
                        • 3396
                        WOW,
                        This machine is far behind. the latest is
                        MN-CON v90.03
                        D-CON v38.02
                        BOOT v70.01C
                        It probably has never been flashed before.
                        • D_L_P
                          Self Employed
                          • Oct 2009
                          • 1196
                          The C1 should boot in under 10 minutes. If you are getting this message after 10 minutes 90% of the time it is corrupted system software. You will need to find the C1 system software CD and use PDL downloader and the parallel port to install the software.
                          Try this, turn off/on the C1 and on the copier go to the printer tab. After about 30 seconds the screen will change form "Wait..." to "Enter Setup?". This screen only appears for about 10 seconds so if you missed it you will need to reboot. Press yes to enter setup and it should take you to a menu to run diagnostics, clear server, install software, restore to factory defaults etc... Do the clear server and since this is a new install go ahead and restore to factory defaults. If you can't get past this screen and only see "Wait...." the system software is corrupt.
                          • nivssluck
                            • May 2008
                            • 228
                            Agree on that D_L_P!!!! for me the maximum is 5 minutes...
                            • mrfixit51
                              Lead Service Technician
                              • Oct 2008
                              • 1975
                              One other snippet of advice here is any change you make to the copier will not have any effect till the copier is turned off and back on again...
