Paper jam and blur scanning
  • Zoollanderhu
    • Aug 2010
    • 76
    [Jamming] Paper jam and blur scanning
    Hi Everyone!
    I've got a iR1022. It has two problems, the first it "irons" an edge on the paper when it prints or copies in duplex mode. Only at duplex. I've already cleared the rollers at the duplex unit. What can effect that the double sided copies and prints has an edge ( ironed edge) It doesn't jam , just comes out with edge.
    Maybe the fixing film? but why doesn't it edging at simplex mode? why just duplex?
    The other problem is when copy from the ADF on the higher part of the CiS it blurs on the copy. The prints are ok. Evethough when copy from the document glass it is better. ( the little glass under the adf is already cleared. )
    Error or defect of the CiS?
    Any guess?
    thank you in advance for any help.
    Best regards,
    Norbert
  • MrB
    • Nov 2009
    • 147
    The blured image from the ADF, maybe caused from the ADF's hinges
    One of them may not be sitting correctly, causing the ADF to sit higher that the rear (on one side then the other)
    Try replacing the hinges FM2-4974
    • Zoollanderhu
      • Aug 2010
      • 76
      Thanks man!
      tomorrow I'll try it. Really apprecite that idea.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5018
        blur scanning
        ir1022-006.pdf
        • Zoollanderhu
          • Aug 2010
          • 76
          Originally posted by zoraldinho
          blur scanning
          [ATTACH]7297[/ATTACH]
          thanks for the bulletin anyway have you ever met with the smae problem?
          Is the new set of hinge unit resolve the blur scanning?
          Thank you in advance!
          • zoraldinho
            • Mar 2008
            • 5018
            Hinge is not a problem.Frame,base is broken.
            • Zoollanderhu
              • Aug 2010
              • 76
              Hi!
              Exactly how you've said. the problem was the incorrect hinge and it broke the base frame :S. Must be replaced.
              Thank you for your help.
              Best regards, Norbert
              • zoraldinho
                • Mar 2008
                • 5018
                Hi!
                Any time dude.
