C5185 Fuser Unit
  • JEFFakaMAX
    • 6
    C5185 Fuser Unit
    The $1900 new OEM replacement cost seems a bit crazy.
    Is anyone rebuilding these?
    I am getting the "smear" along the side edge of the sheet. When my C3200's do this it is usually the Fuser Unit.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    What kind of smear?Smear is usually transfer belt issue.
    • JEFFakaMAX
      • 6
      See pic... only on that edge, and never when set to Heavy 1 or 2 stock.
      • teckat
        • 16083
        cold be a paper arc issue at Trans Roller
        check your image on ITB before transfer to paper/ remove that small side cover over Manual Feed tray & watch image process on belt/ - if ok check Trans Roller position- if ok remove and inspect fuser unit
        • Fer
          • Nov 2009
          • 267
          Never had this fuser giving any image problems, they just tear and break and give an E0007 error. Smearing is ussually the lower side itb scraping to the metal itb cover.
          • teckat
            • 16083
            have to agree/
            I forgot that plate can become dirty and bent & cause a smear of image on corner
