Canon IRC5870 Error E00014
  • Tim C
    • 167
    I am getting a Code E-000014 on this C5870U Looks like flat spots on the Top Fuser roller
    might be causing the problem. They only have 25K on them. Any reason that this is happening? Are there any updates for this issue?
  • charm5496
    • 2387
    You are correct on the flat spots causing your issues with the error code
    there are service settings that can help with the flat spots, but we also take the NIP pressure down a full turn as well. The more these things sit the worse they are.
    Try these settings after rebuilding the fuser:
    Level 1 FX-CROT at 3
    Level 2 DM-SW at 0, FXMSG-SW at 0, FXERRLVL at 3
    • Fer
      • Nov 2009
      • 267
      Lower the sleep time to 90mins max. U can lower pressure till four full turns. Replace the lower roller if is has a flat spot too.
      Replace the whole machine for a surf fixing type.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        As has already been alluded to, this problem occurs because the copier sits still too much. The problem is the same as the 3200 series. Software and settings changes can minimize this problem, but I predict that your fuser rollers will never make life. I only have one iRC5058 left in my world, and I look forward to the day it gets replaced. In the meantime, when I get the call for E014, I just replace the 2 rollers...
        • anothertech
          • 1771
          There was a connector mod that helped a lot, I can't remember if it was for this machine or just the IRc6800, does anybody know for sure?
          • mrfixit51
            • Oct 2008
            • 1975
            I recall one for the 3200, some sort of fan mod...
            • charm5496
              • 2387
              there was a connector mod which was just a spacer to make the connector stick out further. You can accomplish the same thing with a few washers, but the 70 series already had the mod installed on it.
              We still have a couple dozen of these wonderful machines left and they are being replaced rapidly by the 7055 and 7065. We are going to donate our last one to the state engineering school and let them blow the sucker up!!! I will get video from it if they let me.
              • Canuck
                Tech Specialist
                • 1713
                Lower the temperature on both of the fuser rolls in service mode. As stated,back the nip off about 3 turns,jog the rolls(service mode) and make sure the heat adding/removing roll is clean. These fusers run filthy and if the heat adding roll is dirty,its thermistor will make it run hotter. When it contacts the ufr,the web is cammed away from the ufr.Make sure it is doing this correctly. That heat adding roll will put flat spots on as well. I can get 120k out of a set of rolls no problem. The FXMSG-SW setting will have no impact on roller life. It just disables roller life message and error generated when counter reaches threshold(E008).If you are only getting 25k out of the rolls and resetting counters when replacing them you will NEVER get a fuser life error anyway! Canon cheaped out and used a thin aluminum ufr to save money,thats why it has extra heat roll. Thin aluminum doesn't retain heat at all. "More accurate temp control" with heat adding roll is BS.
                • JPP Océ
                  i really hate those model c6800 and those copier was suppose to do only 20% of color and a lot of client thinks that is a color copier but its a hybrid copier
