Canon IR 4570 accordian paper jam!
  • gerryhuerta
    AccService
    • Jul 2009
    • 198
    Hello copytech, I have a canon image runner 4570, and every morning as i go to start up the copier and make a print or a copy, the paper jams at the fuser. Some of the page does go past the fuser about three inches but the rest of the paper is stuck inside the fuser like an accordian. The copier will do this for about 45 minutes in the morning, I think it does this untill the machine warms up, because after a while it copies and prints just perfect. also some times in the afternoon while the machine is in power saver mode and we turn it on the paper might jamm, depending on how long its been off for. If anyone has any info. or suggestions please let me know because this machine is driving me crazy. Thanks in advance.
  • THUK
    • Jul 2008
    • 195
    hi is it 0207 or 0107 jam codes if so look in side the right hand door deflector it sits on small rubber tabs that become sticky or deformed.
    • gerryhuerta
      AccService
      • Jul 2009
      • 198
      Thanks for the reply, how would I find out what type paper jam it is? Where would I find the number? Thanks.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5005
        In SERVICE MODE copier/display/jam
        • gerryhuerta
          AccService
          • Jul 2009
          • 198
          Oh thats crazy, I seen that piece and it had some lubricant on it, I added more and after I moved it around a little bit i closed everything up and it worked!! i knew it had something to do with it!! So what do you guys suggest i do? should i take it off? buy a new one? any advice on what you have done?
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            I rip them off,,, lubricating them is only going to add to the problem. They are supposed to be dry foam pads. They break down and get compressed and gooey. Their whole reason for being is to act as sound deadening material. I have never heard the guides that I ripped these chunks of foam off of, and the machines ran well afterward.
            "Morning sickness", is a dead giveaway to this issue, after you have removed the jam, that guide is freed up, till the machine sits at rest for awhile, and the gooey pads grab back onto the guide.
            • gerryhuerta
              AccService
              • Jul 2009
              • 198
              Thanks for the advice, I didn't even notice the pieces you mentioned, ill go back and try and get a shot of what the piece looks like. I will try running it with the piece off to see what happens.
              • Matoku
                • 173
                hi gerry.
                Do you solved your paper jam problem yet?
                • mrfixit51
                  • Oct 2008
                  • 1975
                  I believe you will be pleased!
                  • buihung
                    wet paper
                    • gerryhuerta
                      AccService
                      • Jul 2009
                      • 198
                      No the problem is still not solved because i have not gotten out there yet, i will be paying them a visit today in the afternoon... so please stay tooned and cross your fingers.
                      • gerryhuerta
                        AccService
                        • Jul 2009
                        • 198
                        so I returned to the machine and I pealed off the two small sound deadning pices, it was in the afternoon so I will wait for the morning to see if it holds up.
                        • gerryhuerta
                          AccService
                          • Jul 2009
                          • 198
                          So far so good!! i called the customer in the morning to check up on the machine to see what was going on and the y said it had jammed in the morning but it was down at the casset in the pick up section. after that the machine has been running just fine!! will see tommorow or later on in the day to see if jamming continues. thanks for all of the help with this machine so far.
                          • mrfixit51
                            • Oct 2008
                            • 1975
                            You're welcome..
                            The only thing I would advise you to do is make sure the right side door updates have been done , to assure your self of the best possible performance. The new inner door guide with the steel spring, bottom door that goes along with it, and the cassette 1 & 2 vertical rollers, they are grey in color as opposed to the black ones. Then the beasty will run as well as possible for you...
                            • Canuck
                              Tech Specialist
                              • 1713
                              When you put the new door on,take a piece of the black foam from the old door and glue it in place of the old bumpers. Glue a little square of a transparency on top of them. It will never get a divot in it and stick again. I have had customers complain when you remove them...it clicks a little bit,some machines more noticably than others.
