CANON IR 1023
  • cucuklotz
    • Mar 2007
    • 611
    CANON IR 1023
    HI,
    I have machine that is making GROANING sound when paper hits fuser,exit area.Im not sure if it is fuser,exit rollers or the tail edge of the feed cycle that cuases noise.It only seems tp Groan during copy cycle.If you have had exp.with machine and groanig noises can you tell me what to look for(besides an Exp. tech)My exp on model is limited to this one unit and some 6550s machines.
    thanks for any help, ANDY
  • DAG COPIERS & COMPUTERS
    • Oct 2010
    • 860
    The best approach is to be on the machine and make a functional test,i.e. try to run many copies while studying the fault, paying particular attention to the GROANING noise. NOISE ussually occur because of FRICTIONAL FORCES between surfaces in contact. You already have a clue that it happens only on the "copy" function, that is good lead. Be systematic and you should be able to narrow the noise to a particular functional block, and eventually to the exact 'area' or part, after which u take corrective measures; may by lubrication or whatever. try!
    • cucuklotz
      • Mar 2007
      • 611
      HEY PAL<
      I understand how to troubleshoot a noise on a machine.Ive been doing this for 35 years.All I was asking is IF you know the machine and are there some noises prone to this machine and where,so I dont have to spend a lifetime on a machine that I wont make any money on at that point.If u want to help ,FINE,If not I give give a TINKERS TOODLES
        • Oct 2010
        • 860
        Why then bother about a machine you are not to make money on? I've never done that in my 25 years of service in this business. Business is all about making or losing money.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 4999
          Originally posted by cucuklotz
          HI,
          Usually fuser work fine on this model.Problems are the drum and developer unit.
          • Brian8506
            • 1658
            HEY DUDE! If thats the way you come here looking for help, you're not gonna get too many responses.
            • cucuklotz
              • Mar 2007
              • 611
              I come here LOOKING FOR HELP,not dripping sarcasm telling me about what a groan is.I KNOW<the simple request wasDO YOU* KNOW THE MACHINE AND HAVE EXPERIENCED NOISES AND FROM WHERE".THE models I KNOW intimately ,I can help others who are new to machine with so they wont have to spend 5 hours and a can of WD40on.On an older model that can be replaced inexpesively,HOW much can I hurt a customer with a service call with.If you know a machine GENERALLY has noise issues from A particuliar cluth for EXAMPLE,THEMN Offer the help. THATS I kind of help I expect from someone.I wish I had freedom of spech here,unfortunately the machines i know best HAVE COME AND GONE,so I am not talking from a position of strength here.I WOULD IF I COULD HELP A FELLOW TECT THAT WAY.The bet I could say is <SHOW A LITTLE RESPECT FOR an old timer which you would do if you were really GOON HOO for your profession
              • fuser101
                • 13
                cucuklotz,
                We see a lot of fusers during our repair process that have torn films at one end after the machine has been in the field for a while.
                This has been known to cause a "groaning" at times.
                Unfortunately,it is very difficult to see the film in the fuser while it is still in the machine.
                I can get you a refurbished and like new fixing assembly for a very good price if you find that to be the cause of your noise.
                I also sent you a PM.
                good luck
                • Brian8506
                  • 1658
                  With that attitude, I wouldn't even think of helping you. That guy was trying to help and if it didn't help you solve your problem, say thanks anyway and move on. Im right in Jersey and could get you a fuser too but I think I'll pass,
                  • teckat
                    • 16083
                    FIXING ASSEMBLY
                    apply lubricant to the exit drive bushings, on Delivery Roller
                      • Oct 2010
                      • 860
                      Hi, Thank you both Brian8506, and teckat for coming to my rescue on this issue ! I am really still puzzled as to why that guy lost his temper. I suggest that he cools down his temper and take a second look at my initial post, and he will realise that i gave him one of the best possible advices he could. I actually wrote that he should try LUBRICATION! and teckat has offered same advice! Now what wrong have I done? Let any of you re-read my initial post with a sober mind and analyze and draw conclusion, & if I'm wrong I'll say sorry to the guy.
                      • teckat
                        • 16083
                        • cucuklotz
                          • Mar 2007
                          • 611
                          Hi,
                          I still stand by my original post,Take a second look.If Im wrong ill make apology public and private
                          • teckat
                            • 16083
                            Hi,
                            You have been pointed to the general location of your issue, the next procedure is left up to you, either follow or disregard the given suggestions.
                            The length of time in the Field has nothing to do with Procedures, You learn and develop them for yourself. What works for other techs, may not work for yourself.
                            Some Techs are still stuck in the Analog World.
                              • Oct 2010
                              • 860
                              Hahahaha.....aaah, I, the DALAI LAMA ?!!!, Peace to the Tibetans. I hope the Chinese won't start looking for me !.
                              Anyway, I would like to thank you all guys, who have contributed to this thread in one way or the other, & especially teckat who read all the posts, analyzed the issues at hand and then EDITED it and contributed his views.
                              On my side as of now, I Consider this thread closed! .
