Canon Ir105 Error E000222-0000
  • msnone
    WHAT IS THIS ERROR? Please help!!
    • 23010
    Lamp
    Exposure lamp does not light. It could be: Fluorescent Exposure Lamp or Lamp Heater (part of the same assembly), Lamp Inverter, or Lamp Harnass (in that order of likelyhood).
    When you turn on the copier watch the exposure lamp. It should light up at some point during initialization. If it does not light, lights slowly or late, flickers, or does not produce an even amount of light over the length of the lamp it will error out.
    To determine of it is lighting slowly, late, or flickers, the lamp may be turned on in service mode and observed.
    I always replace a fluorescent or xenon lamp and the inverter as a set. Good Luck.
    • msnone
      thank you so much!
      You were right on the money, the lamp did not come on on the ir105.
      Sunday my Ir8500 reported an E202!!!!!! when it stopped working.
      thanks a million again.
      • SF Tech
        • Sep 2009
        • 14
        Hello,
        Is it the same for IR-8500?
        Lamp is on, can rum 50 copies until code show up again
          • 23010
          It's a similar build. The same advice holds true. =^..^=
          • pmailfl
            • May 2009
            • 35
            I am having this same problem, and do not care about scanning or copying right now.
            Is there a way to "bypass" it until a tech gets out here so I can send print jobs to the machine through my network?
            I tried *28*, Funtion>Clear>Err, but it doesn't work.
            • davidj7
              • 1107
              you need a good lamp in the machine for it to be work.
              a machine is only as good as your tech : source:screwtape ; the scary one
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                I agree with davidj7,, the copier has a routine it has to go through upon starting up, there is simply no way to avoid it.
                • addoncopier
                  • Feb 2010
                  • 114
                  2 photoreceptor in the scan lamp there, just blow it. then close it back.
