Exposure lamp does not light. It could be: Fluorescent Exposure Lamp or Lamp Heater (part of the same assembly), Lamp Inverter, or Lamp Harnass (in that order of likelyhood).
When you turn on the copier watch the exposure lamp. It should light up at some point during initialization. If it does not light, lights slowly or late, flickers, or does not produce an even amount of light over the length of the lamp it will error out.
To determine of it is lighting slowly, late, or flickers, the lamp may be turned on in service mode and observed.
I always replace a fluorescent or xenon lamp and the inverter as a set. Good Luck.
Hello,
Is it the same for IR-8500?
Lamp is on, can rum 50 copies until code show up again
It's a similar build. The same advice holds true. =^..^=
