Canon PC 745 paper feed problem
  • technics
    • May 2025
    I have a canon pc745 that will not feed paper due to a spring that has come off at the rear of the paper feed ass'y. Would anyone have this part of the service manual or parts diagram so I can see where the spring needs to go? It is sometimes obvious where it hooks to but not in this case. Thanks for any and all help.
    Julian
  • kos
    Don't have a diagram, but I had the same problem. If you stand in the rear of the copier with the clamshell open, look towards the left of the upper portion of the clamshell and you will see the gear that applies drive to the feed assembly (it ratchets) that's where the spring goes.
    • teckat
      • 16083
      Julian
      U mean this spring on a single feeder type
      or this Spring
      • technics
        Originally posted by teckat
        [ATTACH=CONFIG]8339[/ATTACH]
        or this Spring
        [ATTACH=CONFIG]8340[/ATTACH]
        It may be the first one but it is still hard to tell. Do you know of a diagram that can be found on the Internet. Thanks for the reply.
        • technics
          One end of the spring attaches to a metal bracket on the lower part of the machine towards the left back. It is obvious it keeps the tension of two gears meshing but I can't seem to see where the opposite end would hook. It hooks to something behind where the clam shell is still together. Not a great description I know but is there any diagrams on the net. I can usually find the needed diagrams on the net. Thanks for your reply.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5001
            Check if the customer by a new one in the time.
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              There used to be a spring mounting point on those clamshells that used to break off. The point was behind the main circuit board on the back. You had to really gut the machine down to get to that area. We used to use a self tapping screw through the rear frame area where that spring used to mount to. If I recall correctly, it was the rear developer latching pivot that would break that lug.
              Thankfully, the last one I had to repair was ages ago, senility may have altered my perception of that process, proceed at your own discretion based on that caveat...
              • throwaway
                canon_pc745_1.jpg: Broken plastic tab where spring used to attach.
                canon_pc745_2.jpg: My fix...use at your own risk, your mileage may vary, etc.
                canon_pc745_3.jpg: Installed through slit in adjacent support and bent out of the way.
                • teckat
                  • 16083
                  • mrfixit51
                    • Oct 2008
                    • 1975
                    Nice engineering, that was a different problem than the one I used to face, never had that one break on me,,, lucky me.
                    • megamil5
                      Thanks Thowaway
                      your post and picture, including instruction are very helpful,
                      I've been look all over the place for that spring to go in to, did not know the slap
                      was broke off,
                      thanks a lot
                      Tan
                      • throwaway
                        was broke off,
                        thanks a lot
                        Tan
                        I'm glad that my information helped you! I have been helped so many times by other peoples posts around the internet...it feels good to give a little bit back.
                        • artsy
                          Re: Canon PC 745 paper feed problem
                          I printed everything and will attempt a look tomorrow to see if this is the fix. It sure sounds like this is why it is not responding.
                          Be Good and may you get good deeds sent your way for the one you have passed along to so many.
                          Artsy
                          • mrfixit51
                            • Oct 2008
                            • 1975
                            Pay it forward! That is why most of us are here...
                            • teckat
                              • 16083
                              Artsy
                              The Dude.jpgyeah'
