Canon IR3045 , Rippled copies A3 trailing edge
  • Jezzer
    • Oct 2010
    • 10
    [Misc] Canon IR3045 , Rippled copies A3 trailing edge
    Hi Guys ,( info required)
    I have an IR 3045 that prints out A3 copies with a ripple along trailing edge side (last 2-3 inches) , have changed fuser film and pressure roller , replaced feed assm ,and reg flag arm etc. A4 copies are fine , Cheers.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Do you have finisher?
    • Jezzer
      • Oct 2010
      • 10
      Yes , it has a Q4 finisher and bridge unit , must admit I haven't tried without them on, there are no signs of any obstructions and both paper paths have been cleaned
      • zoraldinho
        • Mar 2008
        • 5007
        This kind of issue i solve with replacing roller,paper feeder
        • asser145
          • Mar 2011
          • 40
          i have the same problem. i change heat roller, pressure roller, paper feeder of a3 cassete,
          and the printes makes a rippled copies A3, along trailing edge side (last 2-3 inches)
          • asser145
            • Mar 2011
            • 40
            this is my problem
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Pop the plate off of the top of the right door and set Option>Acc>out-try to 1, restart copier, and choose that exit for paper. Run it that way to see what happens...
              • teckat
                • 16083
                Check if the 1st paper delivery flapper is broken in the 2nd delivery frame assembly.The part, FL2-1212-030 can be seen in the image below.
                part tends to break at the point where the solenoid actuates the flapper.
                • Canonbloke
                  • 17
                  Go into service mode level 2 options, body and look for FXSP type of name, this is the fuser speed setting, set it to 3.
                  • asser145
                    • Mar 2011
                    • 40
                    tanks for eveybody
                    was right canonbloke. when I change the speed of fuser, the rippled disapear.
                    • andym
                      • Oct 2008
                      • 90
                      There's a canon fix for the IR35/4570. Use that. I've seen this before. It's in Service Mode>Copier>Option>Combo. It's complicated. 01042011614.jpg They all need to be set to '1'. ie 1, 2, 3, 1. 1,2,4,1,1. 1,2,5,1,1,1. 1,3,4,1,1,1,1. 1,3,5,1,1,1,1,1. Your display should look like my picture. Run a good hundred copies to make the machine reclibrate. Don't alter the fixing temp.
