This message appears often when copying or scanning. The scanning glass is not dirty or worn. Have cleaned scanning glass, optics and document feeder rollers above scanning glass. Thx
IR5570 "Original may not be scanned clearly........ Clean scanning glass."
JPP Océ
you need to go on the service machine and adjust the sensibilite of the sensor ... the sensor take a reference test still if you clean its not that like i said you need to chance the value -
JPP Océ
JPP Océ
Also, to get away from the annoying "Clean slit glass" warnings, you can go into Additional Functions>Copy Settings> 6th 0r 7th page and turn off the dirty slit glass notification..."Once a King, always a King, but once a Knight is enough!"
