IR5570 "Original may not be scanned clearly........ Clean scanning glass."
  • bartman
    • Sep 2010
    • 50
    This message appears often when copying or scanning. The scanning glass is not dirty or worn. Have cleaned scanning glass, optics and document feeder rollers above scanning glass. Thx
  • JPP Océ
    you need to go on the service machine and adjust the sensibilite of the sensor ... the sensor take a reference test still if you clean its not that like i said you need to chance the value
    • charm5496
      • 2387
      copier>option>body>DFDST-L1 and L2. Change them both to a 1
      • JPP Océ
        thats it
        • bartman
          • Sep 2010
          • 50
          I changed the DFDST-L1, L2 to 1 like you suggested and it seems to have worked. Thank you very much.
          • JPP Océ
            • mrfixit51
              Lead Service Technician
              • 1975
              Also, to get away from the annoying "Clean slit glass" warnings, you can go into Additional Functions>Copy Settings> 6th 0r 7th page and turn off the dirty slit glass notification...
              • charm5496
                • 2387
                you are welcome!
                • Canuck
                  Tech Specialist
                  • 1713
                  Also in service mode...COPIER>OPTION>BODY...set DF-BLINE to 1 then reboot. This will disable edge emphasis when using doc feeder and reduce chances of lines when glass is dirty.
